  • Guests: 58
Sstc driver using 12-120v car inverter
teslarevolution
Wed Jun 24 2015, 05:51PM Print
teslarevolution Registered Member #16903 Joined: Thu May 09 2013, 08:00PM
Hello I was wondering if can use a 120v car inverter to drive a small coil? Since looking at the board it seems to be a h-bridge inverter all I would need to do is take the 60hz output and increase it to the resonance of the cool, if it's possible?
hen918
Wed Jun 24 2015, 07:31PM
Most commercially available inverters use a 2 stage design where the 12 or 24V is chopped using a single or two MOSFETs (usually a(n) IRFZ44N(s) in my experience) and then fed into a flyback transformer in the 10s or 100s of kHz, that outputs a little over the peak voltage of mains, which is then rectified and then fed through an H-bridge at 50 or 60Hz.
It may be possible to use the first stage circuit to feed a SSTC instead of the transformer, but the second stage (the H-Bridge) is not designed for such a high frequency.
teslarevolution
Wed Jun 24 2015, 07:54PM
So just replace the flyback with the primary tank circuit, btw the mosfet on the primary in the 1st stage uses a ssf7509, 2nd stage uses 2 vti630
Btw could I put a stw88n65m5 or higher powered mosfet as long as the gate drive voltage is within the same range?
hen918
Fri Jun 26 2015, 05:14PM
Hummm, you could try, but all you would be left with is a MOSFET driver that would have to be set to the resonant frequency of the coil, if it can be adjusted, and a MOSFET.
You might as well build a proper SSTC driver.
