  • Guests: 56
01/04 bomberguy92 (34)
01/05 Timo (40)
01/06 Ash Small (63)
At the assembly stage. Looking for feedback (no pun intended)
crashstudio
Tue Jun 09 2015, 02:00AM Print
crashstudio Registered Member #54484 Joined: Sun Feb 15 2015, 06:18PM
Here it is. I've completed all the components and have begun assembly. Any feedback is greatly appreciated at this stage. I really just want to be sure I'm on the right track.
All pics are below including the schematic I'm following. I'm assuming the safest bet is to ground the NST to RF, not house. Also, before you warn me I am going to install a strike rail.
The NST is 15kv 60ma
The A/C filter circuit consists of an RFI EMI Tesla Filter 15 Amp's 115/250vac and 2 PFC caps from microwaves in parallel totaling 165uF. TeslaMap suggests 165uF for optimum PFC.
Capacitor measures 10.9nF - resonant cap for this NST is 10.6 (at the time I didn't know an LTR was better or I would have added more plates). It's constructed with 30 sheets of 8 X 10 polyethylene windows and 28 sheets of aluminum foil.
It will soon be replaced with an LTR MMC. I've already ordered 40 0.15uF, 2kV 942C20P15K-F caps and will be assembling 2 strings of 17 for a total of just over 17nF.
Toroid is 4" aluminum ducting with aluminum tape wrapped all around it and 8.5" pie pans bolted in the center. When I entered it's dimensions in TeslaMap it said the capacitance is 18.3pF
1433815258 54484 FT0 Tesla Coil Schematic
1433815702 54484 FT171609 20150512 212641
1433815702 54484 FT171609 20150526 193310
1433815702 54484 FT171609 20150526 193323
1433815702 54484 FT171609 20150526 193338
1433815702 54484 FT171609 20150607 230424
1433815702 54484 FT171609 20150608 213028
1433815702 54484 FT171609 20150607 230355
1433815702 54484 FT171609 20150607 230341
1433815702 54484 FT171609 20150607 230936
1433815702 54484 FT171609 20150607 230958
Blackcurrant
Tue Jun 09 2015, 11:50AM
A few things I would look out for
Keep all the HV parts smooth, so there's less likely to be any unwanted break out
you may want to put some plastic between coils, it might flash over near the bottom part
make sure the tunings ok take your time over this bit
put a sharp breakout point on the top so you know were it should be sparking from
If there's any small fires turn it off quick :)
Tue Jun 09 2015, 12:07PM
This build looks good. Nice construction too. I love the NST protection features - you will be happy you have those in place. I learned the hard way frown With regards to the ground, I always grounded the secondary to a dedicated RF ground, but kept he NST grounded to the house ground. I would worry about ground loops, but I am no expert. One of the best spark gaps I ever built was a forced air quenched gap. It worked really well. Fast quenching really helps. That said, I wonder if the length of copper tubing will allow the primary spark to travel along its length for too long before being extinguished? How do you adjust the spark gap for max voltage?
crashstudio
Tue Jun 09 2015, 10:09PM
Graham Armitage wrote ...
Each copper pipe is 4 1/4" long. I got the design from youtube and the guy showed it in action in a later video, seemed to work great. The gap between each one is 1/32", I got that from a couple different coilers. As far as adjusting the gap, I can change it but it would take a good amount of time so I'm just hoping it will work the way it is. Some day I'm going to design one that can be adjusted by turning a screw.
As far as the NST grounding I had the same concern, you're probably right. I'll just change it to mains ground. Thank you, and thanks for the compliment.
crashstudio
Tue Jun 09 2015, 10:13PM
Blackcurrant wrote ...
Thanks. You mean plastic between the bottom of the secondary and primary right?
Hazmatt_(The Underdog)
Wed Jun 10 2015, 03:50AM
Why so much primary?
You should have 5-10 turns of primary and that's it.
Find the resonant freq. of your system at turn 5-7, and adjust your secondary accordingly.
Remember, every excess inch of primary, AND HOOKUP is LOSS.
Blackcurrant
Wed Jun 10 2015, 07:05PM
yes, like a plastic tube to stop it jumping from the inner primary coil to the secondary. It might not happen but it does look close to me.
If your gap fails to fire, try a re-tune or link out one of the gaps.
Have you thought of a safe way to discharge the caps? If something fails there could still be charge in them, trust nothing!
Also the secondary coil may hold a bit of static after use
it'll be fun, good luck
Dr. H.
Wed Jun 10 2015, 07:56PM
Hi there,
I am a bit worried about the terry filter -did you remove the unnecessary copper pads from the board ? On some of those boards the distance between them is really small (for easier soldering) and might flash over.
Cheers smile
crashstudio
Thu Jun 11 2015, 02:52AM
Dr. H... the board is blank. It was made primarily for a Terry filter. In this pic its not even complete. I'll post a new one
Thu Jun 11 2015, 02:53AM
Some of the Vero-board is completely copperless, and this one looks to be that.
I'm a bit concerned about your 630V caps, I think they're going to die.
You might want to try to run your filter with some high voltage for a short while, turn off, and see if the caps are hot.
