  • Guests: 54
PMT S-curves
coillah
Wed May 27 2015, 01:25AM Print
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
Does anyone have access to this:
"Relative spectral response data for photosensitive devices ("S" curves)," JEDEC Publication No. 50, Electronic Industries Association, Engineering Department, 2001 I Street, N.W., Washington, D.C. 20006 (1964)
Cannot find the dang thing any where. I have a tube marked S-2. I need to know its spectral response.
Thanks!
Wed May 27 2015, 02:58AM
These days anything not found with 10 minutes of Internet searching counts as a respectable challenge! Any chance your label once said S-20 or S-25? I found this Image with a curve for "Super S2", but on closer inspection it appears to be "Super S2 5".
1432695221 2099 FT171421 Photocathodes
from Link2
Good luck! What spectral range are you interested in?
Wastrel
Wed May 27 2015, 04:18PM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
Searching for "S2 photocathode" produces a few results and a description. - "S2 photocathode with larger spectral response. (from 180 to 900 nm), but reduced efficiency, being only 5% at its maximum." (larger and reduced being relative to another detector). The S response combines the photocathode and the window response so presumably your device has a quartz window.
Wolfram
Wed May 27 2015, 06:19PM
This Link2 excellent handbook also contains some limited information:
1432750771 33 FT171421 Photocathode
johnf
Wed May 27 2015, 07:29PM
S2 tubes were manufactured by various makers I did use one from Thorn EMI many years ago and 200nm to 900nm is correct as we used it on a spectrometer for looking at stars. We also cooled the PMT to -50 degrees celsius to minimise noise
coillah
Wed May 27 2015, 08:53PM
NICE!
This is awesome stuff. I've pinged JEDEC for the archived publication. It wasn't scanned in 1997, hence not being listed on their site. They're looking into it tomorrow. I knew you guys would have something.
