  • Guests: 37
Timo (40)
01/06 Ash Small (63)
01/06 Oatmeal (38)
01/08 Lyonel Baum (77)
HP 34119A High Voltage Oscillscope Probe.
Sat May 23 2015, 03:57PM Print
Ive got a new probe but i cant find any user manuals or PDFs for the HP 34119A. Im wanting to use this in parallel with home made probes so we can get an idea of what what works when we build our own.
Dr. Slack
Sat May 23 2015, 04:21PM
This is the best that can be done in 3 minutes, it's not a specification sheet, but given that it's obsolete, it's probably all you will get (unless someone has one in the original box with the original paperwork!) HP changed to Agilent and then to Keysight, this is from the Keysight site.
34119A High voltage probe
Length: 1.5m (5ft)
Crest Factor: Less than or equal to 2
Division Ratio: 1000:1
Input Impedance: 500Mohm (+/-1%), shunted by 3 pF (approx.)
Compensation range: 20-100pF
Maximum Input Voltage, DC Voltage: 5 kV, AC Voltage (0 to 250 KHz): 5 Vrms, AC Voltage (250 KHz - 1MHz): 2.5 kVrms
Accuracy: dc-100 kHz: +/- 1.5%, 100 kHz - 1 MHz: +/- 2.5%
wow! get the AC voltage limit up to 250kHz, no ripple allowed!
They recommend replacing it with the 34136A,
34136A high voltage probe
Multimeter impedance: 10 MΩ
DC Accuracy, 2% from 1 kV to 20 kV, 3% to 40 kV
AC Accuracy, 5% at 60 Hz; derates with frequency to -3 dB at 300 Hz
Input resistance: 1000 MΩ
Maximum voltage, 40 kVDC
Length: cable is 1 meter
Not a high frequency probe, 3dB down at 300Hz!
Sat May 23 2015, 06:27PM
so as it approaches 250kHz its tending toward DC only? it seems like its still good at 1Mhz at 2.5Kv?
Or am i missing your point.
The 300Hz one looks like crap.
