  • Guests: 51
Hanzie (31)
badger (52)
h3X (40)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
[moved] Firm grip on brass balls
Sun Apr 19 2015, 10:14AM Print
I needed to securely hold a couple of 1/2" diameter brass balls with threaded blind holes, in order to enlarge and re-thread the holes.
What worked was a slightly undersize hole in a scrap of 1/4" aluminum plate. The ball was screwed onto some 10-32 threaded rod in the chuck of a drill press, then pressed into the plate. That held it, unmarred, with axis vertical for drilling and tapping.
The second ball started to spin while being drilled, and re-pressing didn't fix it.
Blue Loctite 242 thread locking fluid and some cyanoacrylate accelerator did an adequate job of gluing it in place for the rest of the job.
1429436523 2099 FT0 Dscn9692cr
Why not buy correctly threaded balls to begin with? I only needed one, to replace a missing decorative finial on a fireplace screen. Minimum order quantity was five balls (for about $12) so I planned to replace the other three finials for matching appearance. Learned a lesson: this screen needs two balls with 10-32 threads and two with 1/4-20 threads! frown Fortunately, the thread I had measured and bought for was the smaller.
Dr. H.
Sun Apr 19 2015, 03:44PM
Hi there,
thanks fro shearing your solution.
Just an idea - there are vises with V groves (don't know how it is called) - designed for gripping round objects.
Other solution is to use a piece of scrap aluminum a bit bigger than the diameter of the ball. Make a hole in it with a diameter as close as possible to the ball. Squeeze it tightly in the vise (the aluminum deforms and locks the ball).
Cheers smile
Dr. Slack
Sun Apr 19 2015, 04:09PM
I use two plates, each with a hole in it of 0.7 or so the diameter of the ball, and clamp them together with several bolts spaced around the ball. That's the same clamping geometry as holds the 'elbows' of the 'any angle' bench clamps. Sort of like a circular V-block.
Bored Chemist
Sun Apr 19 2015, 05:06PM
I like the idea of using the drill press to make sure that the hole is vertical.
Ash Small
Sun Apr 19 2015, 05:38PM
Soft wood also works, as does a few layers of cardboard. I often use aluminium as well, but soft wood is my prefered choice.
Thu Apr 23 2015, 08:07PM
your more spiteful and pithy than i good sir... cheesey
