  • Guests: 40
  • Members: 1
RickR (18)
TheBoozer (58)
invader (50)
TheAncients (32)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
self excited homopolar generator (no PMM!!!)
1 2 3 4  last
Salvador
Mon Mar 30 2015, 08:00PM Print
Salvador Registered Member #54402 Joined: Mon Feb 02 2015, 11:09PM
Hi , please help me out i have thought about this yet havent generated useful answers elsewhere.
The idea is as follows.(for sake of simplicity I avoid more complicated design which would also have higher efficiency and or without brush contacts.)
A faraday disc . A constant rotational torque source that spins the disc which we assume as input energy into the system.Now as the disc spins no current is induced, because there is no magnetic field present to drag the electrons sideways, or should I say generated since the disc operates on lenz law rather than faraday induction law.
I now inject a kickstart current into the disc so curent flows and so it creates a magnetic field along it's way , given the fact the disc is spinning the magnetic field should now create further current , (assuming I have some load attached to the disc via brushes to make a complete circuit for the current to flow.)
I am asking is this possible and would it work , can a disc like this create its own excitement field for current production without any external magnets or exciting coils , the geometry of the disc can be varied to make the field lines through the disc better.
So would it work, what do you think?
hen918
Mon Mar 30 2015, 08:29PM
Salvador wrote ...
It is one massive shorted turn. Why would electricity flow through the brushes when it can flow through the disc?
Wastrel
Mon Mar 30 2015, 09:31PM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
It's certainly possible for a motor to generate it's own field. The earth's magnetic field is thought to be produced this way. I'm not convinced this setup would do much, the field would be at right angles to where you'd think it needs to be.
Salvador
Tue Mar 31 2015, 07:30AM
hen918 electricity flows through the disc only if its rim is connected to the center to form a closed loop , and the wire connecting them must be sationary or move at a different speed with respect to the disc itself, that much i have learned.
Well a single disc with brushes ofcourse is a very inefficient machine due to the low voltage high current situation.I am using this just as an example for simplicity , a real world machine could have more discs, turns and would also be able to have the b field and more desired angles the perfect angle being 90degrees to the surface of the conductor.
So what do you think?
Dr. Slack
Tue Mar 31 2015, 03:53PM
Self excitation is common in DC generators, see Link2 The difference between these and a homopolar generator is just one of geometry and numbers of turns.
Salvador
Tue Mar 31 2015, 06:00PM
Yes I have read this and where it says self excitation it still mentions field coils only the difference being that the weak leftover field in the armature first produces a small current in them until the current further builds up.
I was thinking in my case with no field coils as they normally come as a separate entity , just the disc and that's it then once current flows through the disc that current produces a b field and that b field continues to produce current as long as the disc is spinning , something like this, will this work? with no separate field coils in series just the disc for example.?
Dr. Slack
Tue Mar 31 2015, 07:08PM
Salvador wrote ...
Current doesn't just magically return from the edge of the disc to the centre, it's carried there by a conductor, which has to close the circuit. This represents both your field winding, and your load (assuming series connected field). If that return conductor is looped a few (N) times, then the H field it creates will be N times that of a straight conductor. Like I said, it's just geometry. Once you've identifed the field path generated by the return conductor and intercepted by the disc, you may want to make some of that iron, to increase the amount of B field you get per H field. That's only fiddling about with the efficiency.
Salvador
Tue Mar 31 2015, 10:26PM
Ok, Dr.Slack, just to confirm , a single disc , yes it has some load atached to it via brushes which also completes the circuit because wthout that there is no path for the current to flow , so brushes , disc and load say a light bulb , and that's it no permanent magnets no field coils no nothing just a start up current kick say from a battery after the disc starts to spin to create the first current and the b field , and this will work?
radiotech
Wed Apr 01 2015, 05:25AM
In a homopolar generator, assume you have magnets.If the disk spins,
and current flows to a load, for example, a homopolar motor ,then the rotational
force is moved from disk to disk.
The same force exerted on the disk of both machines, is exerted on their magnets.
What objects that rotate transfer energy without electricity?
Try thinking about a solution that isn't at all conventional.
Homopolar means one pole. Instead of wires, is there any way of moving the
energy on the magnetic field ?
Why did they build the Barlow's wheel about 200 years ago ?
Wed Apr 01 2015, 07:16AM
Didn't Tesla's version of this use a pair of conductive belts to transfer current between the disks?
1 2 3 4  last
