  • Guests: 75
01/12 RoV IW3IPD (63)
Simple flyback driver circuit
hvduffer
Fri Mar 27 2015, 06:12PM Print
hvduffer Registered Member #54487 Joined: Mon Feb 16 2015, 02:29PM
I came across the following flyback driver circuit
" target="_blank">Link2
( Link2 )
Can anyone explain the capacitor between the dimmer and the flyback primary ?
see attached image
Thanks
1427479829 54487 FT0 Flyback Dimmer
Fri Mar 27 2015, 06:21PM
Given the symbol circle with the sideways "A" is the dimmer, then the cap is there to limit current, so theres no huge current short circuit due to low resistance of the primary. (Notice its in series)
If you look inside a modern dimmer, youll see a bunch of components. Those are there to on-off chop the sine wave of the 60Hz incoming power, but there still needs to be a load that should be a bulb or such. But your primary isnt enough.
I dont like this particular circuit, a 555 timer is easier to start out with, for new people. less lethal generally.
Teodor Zafiroski
Fri Mar 27 2015, 08:02PM
Teodor Zafiroski Registered Member #48007 Joined: Wed Jun 18 2014, 01:00PM
Also, I should note that this design forks on fairly low frequency, far lower than the frequency that the flyback was designed to run at, so the only spark display you will get are sparks at 50-60Hz. Use a 555 set to run at 25-50kHz, it is much safer and will produce longer and thicker discharges, all you will get with the dimmer and cap are high voltage pulses...
hvduffer
Sat Mar 28 2015, 12:31AM
Thank you.
I will take this advice.
HVduffer
kimbomba
Sat Mar 28 2015, 01:29AM
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
This circuit has been around for a long time and is generally used with ignition coils, that work at a much lower frequency than flybacks, a few hundreds of Hz.
