  • Guests: 44
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
High Voltage Fractal Patterns in Acrylic.
Sun Mar 22 2015, 07:25AM Print
Ive seen the typical fractals on peoples skin and ply wood, but is it with in our reach to do so in a solid block of acrylic? ive seen people strike with a nail the block and its created, but i dont know much else? is it capacitive?
ive googled abit, but they're largely random articles without details.
johnf
Sun Mar 22 2015, 07:48AM
Lichtenberg figures
you do need time on an Electron accelerator to create
Bert
Sun Mar 22 2015, 02:40PM
Bert Registered Member #118 Joined: Fri Feb 10 2006, 05:35AM
Patrick wrote ...
Patrick, making these requires a source of high-energy electrons. We use a 150 kW 5 MeV industrial electron beam (from a Dynamitron, a type of high-power DC accelerator) to inject electrons deep inside Plexiglas (PMMA). As the electrons crash into the PMMA, they lose their kinetic energy, ideally stopping about halfway through. With continued injection, a highly-charged negative space charge layer develops inside the specimen, while the outside accumulates a nearly matching amount of positive surface charge. The internal charge injection process is sometimes called "charge trapping". The result is a "plateless capacitor", where the potential difference between the inner and outer layers of the PMMA can easily exceed 2.5 MV. Even a small specimen can hold a large amount of electrostatic energy. When we hit the specimen with a sharp point, we create a small surface fracture, initiating dielectric breakdown between the inner and outer charge layers. If you look carefully, you can see fainter negative surface discharges spreading across the surface from the discharge point. Most of the stored energy is released (called "charge detrapping") in a high-current discharge lasting only hundreds of nS. The 12" x 12" x 1" specimen in the attached image held almost 1 kJ, and the discharge was estimated to be several kA.
A short video that describes the process can be seen here:
Making Captured Lightning
The following web page has just about everything you ever wanted to know about Lichtenberg figures but were afraid to ask: Captured Lightning
1427031835 118 FT169875 403
