  • Guests: 38
01/13 si2030 (62)
DC voltage for an AC rated capacitor
Signification
Fri Feb 27 2015, 01:22AM Print
I am looking for -reliable- information concerning a safe DC voltage rating for AC capacitors.
Mostly, I have seen the V*1.414 rule, or [ V x sqrt (2) ]. This is obtained, obviously, from calculating the peak value an AC signal would apply to the capacitor. So I guess there is also a peak-to-peak rule [2V*sqrt(2)] out there too.
Here are some additional comments I have run into:
The "simple textbook equation" says that an AC capacitor can take
1.414 times its AC rating with DC. However, due to AC causing extra
stress to capacitors, the real-world factor is higher.
"I have seen a few capacitors with an AC rating of 1 kV and a DC rating
of 3 kV. I have seen a few others with the factor being around 2.5."
"I think it's generally reasonably safe to have DC voltage at 2 times
the AC voltage rating, and generally only mildly adventurous to have DC
at 2.5 times the AC rating."
Fri Feb 27 2015, 02:58AM
for foil/film capacitors I have noticed rated Vac = 0.4 x Vdc quite common
and Vtest = 1.5 x Vdc rated, but it is better to look at manufacturers datasheet,
and wiser to not use any component at maximum rated value !
dexter
Fri Feb 27 2015, 06:45AM
the AC rating is sometimes lower than 1.41 due to dielectric looses
Signification
Fri Feb 27 2015, 09:12AM
So, are you saying there are some capacitors with a LOWER DC rating compared to it's AC rating?
