  • Guests: 82
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
induction heater
RateReducer
Sun Feb 15 2015, 09:09PM Print
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Hi.
I built a series resonant induction heater that i wanted to show you guys here.
PLL based. Running on several kW @ about 30kHz.
demonstration:
DSC 0035 Zpsljjg3q1v
DSC 0039 Zpsly9ywgii
DSC 0041 Zpsjtjy69rc
DSC 0044 Zps1hip07lk
after switching off:
DSC 0045 Zpsg44yjkyg
I will upload some videos of the IH in operation soon. I ordered a graphite crucible - will do some experimenting with it. I will post the results wink
Edit 1:
Edit2: received the graphite crucible...
Successfully melted a whole lot of aluminium!!!
DSC 0054 Zpsvkbybgog
DSC 0055 Zpso9130egi
Gabriel35
Sat Mar 07 2015, 11:26PM
Gabriel35 Registered Member #2310 Joined: Wed Aug 19 2009, 08:04PM
So nice! Could you post more details about it?
Signification
Fri Mar 20 2015, 01:55AM
I am working on my first induction heater. I want to start as simple and basic as possible based on one that works. I have acquired ALL BUT ONE component (a noise filter inductor) for the circuit shown here:
Here is what mystifies me...on the first paragraph just below the schematic, the small toroid, L2, is described (and pictured). An inductance of 2mH is specified...BUT, can someone please tell me how to get 2mH (2000uh) out of this small toroid? It is described as having only 8 turns of 2mm magnet wire--I don't even get 200uH! Is there some specific core material (I tried many cores) I should be looking for?? There is also a youtube video based on this circuit that seems to indicate 2mH in an assembled unit.
hen918
Fri Mar 20 2015, 09:04PM
Signification wrote ...
In answer to your last question, yes, there is a massive range of different permeability materials, that will give massively different inductances per turn. I would buy a toroidal inductor that is a similar inductance to the one you want, and then rewind it with more or less turns to get it right. If you just want it for a filter however, the inductance is far from critical; the right order of magnitude should do!
Experimentonomen
Mon Mar 23 2015, 01:01PM
hen918 wrote ...
In my opinion the mazzilli/royer based ih circuit is not worth the time and effort.
hen918
Mon Mar 23 2015, 06:34PM
Ahhh yes, just looked at sig's link: If it is a Mazzilli circuit, the "filter" inductor can be anything between 30 and 200uf from experimentation, I tend to use a 3 series 3 parallel arrangement of 2Amp little torroidal inductors. I have found high powered Mazzilli circuits to be difficult to get right: I had a lot of problems with the MOSFETs dissipating an awful lot of heat. I have since realised this was probably due to "fake" MOSFETs. I'll have to get some from farnell and try again.
Signification
Tue Mar 24 2015, 10:43AM
hen918 wrote ...
What's a fake MOSFET?
I'm guessing maybe those cheap things from China? If so, then I suppose the data sheet is totally useless...unless they make one for the 'fake'. In fact, this is where I got the MOSFETS (STP30NF10) that I am about to use for the I.D. The package was marked (very dimly)as P30NF10. Note the missing "ST". I also just purchased a batch of low-cost HCPL-3120 gate drivers (to switch large IGBt's) which, IIRC, a while back were somewhat hard to find and quite expensive. Similarly, they are dimly marked only as "3120". I haven't used them yet, but the IGBT's are going to be switching 1200v at several hundred amps--now I'm worried!
Wolfram
Tue Mar 24 2015, 11:14AM
Stick to the topic guys, this thread is about RateReducer's induction heater.
Great job on the heater RateReducer, it looks very solid. Do you control power by detuning? I notice the videos have the same titles as mine in my induction heater thread, is this by chance or intentional? smile
RateReducer
Fri Mar 27 2015, 09:48AM
Thanks, Wolfram.
I have no power control - just an inrush current limiter ^^
Oh i did not notice that... Just by chance.
