  • Guests: 45
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
12/18 LD LANGER (38)
Questions, Single Switch Low - voltage Flyback SMPS ...
Fri Feb 13 2015, 07:31AM Print
Ive got to build a small-ish SMPS for my drone as i cant draw power through the balance leads anymore, the loads and voltage drops are too much that way. Power should be 50w max, 12 ,5 and -12 volts from 10 - 14 Vdc input.
Issues i need to address.
1) RFI EMI
2) single switch operation
3) Flux walking to saturation
So, looking and the TI/Unitrode pages and Uzzor2k's work im worrying about saturation. Im trying to remember if reset windings remove power passively or with a diode. Id like to avoid a rest winding if possible or keep it simple to add.
When i wind the transformers i guess ill use copper foil between the primary and secondary, then again around the core externally?
1423812708 2431 FT0 Uc3842 Flyback Converter
Uzzor2k's work.
Can i just keep the core from saturation by leaving the duty cycle below 50% with a tiny load on the secondary continuously?
that pic from here: Link2 ive never used a single switch SMPS that wasnt a iggy coil.
EDIT:
1423814663 2431 FT1630 Reste
Does this diode/winding put the excess volt/seconds back into the power rails? it seems like it.
Shrad
Fri Feb 13 2015, 08:16AM
can't you fit a micro ITX power supply which will be fed 12V, like such ones?
Fri Feb 13 2015, 08:44AM
will they work down to 10 volts input?
Fri Feb 13 2015, 10:50AM
Patrick,
an smpsu ic will not start with a supply voltage less than it's 'under voltage lockout' start voltage
for the UC3842 that's 16V. (+/-1V)
I'd go for something like a UCx825 (x = 1,2 or 3, depending on temp range)
uvlo start voltage is just acceptable at 9.2V (+/- 0.4V)
and the operating frequency can be much higher than a UC3842,
allowing much smaller/lighter magnetics.
A push-pull forward converter would probably be your best topology for multiple supply voltage outputs.
Shrad
Fri Feb 13 2015, 11:49AM
Patrick wrote ...
that's to be checked with them, but such supplies must surely exist... this is however the closest type of readily built supplies you can find which matches your requirements close enough
the price should be approximately the same if you were to create a prototype yourself, though, so it might be worth trying
Fri Feb 13 2015, 04:02PM
well id find one with a lower ULVO, but it was that desaturation winding that worries me. but your suggesting a push-pull, two transistor, two winding transformer. i geuss if im winding a desat and primary, theres no advantage in the transformer in a single switch mode.
Fri Feb 13 2015, 05:04PM
you will need at least four windings (primary, +12, +5,-12) for flyback
adding a bifilar winding to the primary is not a big difference
AND
using one smps ic for all three outputs will probably be lower power consumption
(22mA not counting gate drive) than three separate converters.
AND
overall weight will be lower,
especially if you use the higher frequency capability of the UC1825
(smaller magnetics, lower value capacitors etc.)
There are probably newer/better smpsu ic for your application,
I'm not up to date with developments.
hen918
Fri Feb 13 2015, 07:40PM
Sulaiman wrote ...
Sorry Sulaiman, I don't like to correct people, however you mean a centre-tapped primary. Bifilar are two windings joined back to back, so the overall inductance is close to 0. (One is wound the opposite way) A bifilar winding would just act like a dead short.
Fri Feb 13 2015, 10:04PM
no, I meant bifilar.
it is electrically connected as a centre-tapped winding but wound bifilar.
just an easy way to ensure both primaries have the same number of turns etc.
however I do make mistakes sometimes and we should all help each other to avoid mistakes
so when polite (like you) no one should take offence.
Sat Feb 14 2015, 08:45AM
ok sulaiman ill change to a push-pull topology. but what out radio frequency? i really got to suppress RF since Im flying...
i wont use electrical isolation on the feed back loop, so i hope that path doesn't leak radio waves.
1423907217 2431 FT1630 Pstransformer
I may need a 8 volt winding too. but ill try these first.
