  • Guests: 45
Im wondering if there is any HV drone application?
Fri Feb 06 2015, 01:03AM Print
Im wondering if there is any HV drone application? Other than inspecting 500kv power lines.
if many drones could be upped' with a neon, florcent, or stobes, then G and M code controlled, something like low level altitude fireworks could be shown closer to people.
but i guess it would pose a roof-flame hazard too.
im still thinking of a glow-discharge based on pre-programmed flight so no radio.
Shrad
Fri Feb 06 2015, 08:48AM
you could use laser communication with a rather high range if using a high luminosity IR diode pointed at the portion of sky you use
bandwidth should even be higher than RF... and you could even modulate a IR laser diode with the output of your RF control emitter with a bias tee
Fri Feb 06 2015, 11:46PM
laser or directed light comms, had'nt thought of that. but i guess that still leaves the "roof-burn-down" possibility.
