  • Guests: 57
David (39)
12/23 David (39)
12/25 Kolas (18)
Phase shift ossicaltor on the secondary of transfomer.
Andy
Sat Jan 31 2015, 07:16AM Print
Being look at Pso and would like a 180 degree out of phase from the secondary, to be feedback into the secondary on another coil, but im have trouble working out were the ground connection will go for this.
The transfomer has one primary, im using 30uf caps, four of them an three 100kohm resistors, with this foumla
F = 1/(2*3.152*100000*0.000030*sqrt(6).
I havnt got a circuit has I don,t know how to wire the ground and second coil.
Thanks
Sat Jan 31 2015, 10:20AM
If you are using a transformer it's easy to get a 180 degree phase shift .....
reverse the connection of the secondary !
Andy
Sat Jan 31 2015, 12:57PM
I dont want a 180 shift per say, just want a feedback system.
Andy
Sat Jan 31 2015, 03:50PM
This is what I had in mind, it might not even work as expected.
1422719420 4266 FT168722 Img 20150201 045031
Sat Jan 31 2015, 08:33PM
the two connections labelled 'Meter'
is that two terminals of one meter (what does the meter measure?) or something else?
Andy
Sun Feb 01 2015, 04:42AM
Its the same meter it was meant to messure voltage, but I think I got the bottom coil wired wrong, were currents should add.
