  • Guests: 39
RickR (18)
TheBoozer (58)
invader (50)
TheAncients (32)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
New and advancing technology
Andy
Sun Dec 28 2014, 06:15PM Print
Hi all
Just thought I would share this, 6.5kv 600amp igbt
Wed Dec 31 2014, 06:39AM
I want boxes of these to replace all the failing mechanical relays at work. No more dirty contacts!
Wed Dec 31 2014, 02:43PM
I suppose the next "advance" will be MEMS based relay "chips" consisting of thousands of nanoswitches in parallel.
Thu Jan 01 2015, 10:08PM
They are around for quite some time. IIRC you can get a GTO SCR with even gigher voltage (10kV?) and for currents up to some 3000A
hen918
Fri Jan 02 2015, 04:22AM
Dr. Dark Current wrote ...
Ohooo I want one!
Would make a good alternative to a TSG
Andy
Fri Jan 02 2015, 06:13PM
Cap,s are getting better,
300rms 5kA pulse 500uF 600volt at futureelectronics.com
Dr. Slack
Fri Jan 02 2015, 10:05PM
Conundrum wrote ...
I don't think so. The 'hotswitch' life of a MEMs is rubbish, due to the tiny mass of the contacts. I just don't see any way round that, the periodic table doesn't have any unexploered corners. A great pity, as otherwise they promised to be more ideal switches in many respects than semis, at least from a decade ago. Don't even think about combining them with a series or parallel semi to handle the hotswitch issue, as that loses all of the potential advantages. However, their existence has driven the SOS CMOS people to up their game.
I have recently had to design a DC to 6GHz front end RF switch to take high power without damage, and a shoot-out between MEMs and SOS CMOS had the latter winning on everything that counted.
