  • Guests: 39
LTX (57)
01/29 IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
fiber optic USB link
teravolt
Thu Nov 27 2014, 09:15PM Print
I am working on a version of the QCW and I am using a arbitrary waveform generator to produce the ramp. It uses a GUI driver that it came with and uses a USB link. I want to create a fiber optic USB link that is easy to build I am hoping. My idea is to isolate the computer from the wave generator so EMI won't be such an issue from the tesla. Is it pausible to use a glass fiber or plastic for D+ and D- ? is D- and D+ bi directional? I have been looking around the net but most units that will do this is ferly expensive.
Fri Nov 28 2014, 03:10AM
Wouldn't it be easier to connect the QCW control electronics directly to usb
(and possibly powered by usb?)
then have a F.O. link from the QCW control output to your QCW power electronics?
This way the QCW control is far frrom and isolated from the QCW high power / rfi stuff
and you will not have usb adapter problems.
Fri Nov 28 2014, 06:11AM
Multiple optical wavelengths ie IR and blue might work.
I've found that UV laser diodes are very nice specific sensors and the same goes for the red diodes found in cheap laser pens.
Even if the diode no longer lases (ie COD) one taken out of a dead bluray optical block will normally work fine for this and it reacts to a 405nm blue LED nicely.
teravolt
Fri Nov 28 2014, 08:24AM
thanks for reply Sulaiman and Conundrum. what I did was make a class D amplifier with a analog input. The wave gen timing is integrated with the control circuitry so that the amp and DRSSTC turn off and on with the single wave coming out of the wave gen. the ramp width is controlled by the wave gen GUI
the pictures are of my layout for the controller and a USB isolator that works. when I first ran the power electronics and computer and control on my bench the computer did some weird things like losing link and the blue screen of death. Fortunately it was fixed by separating the computer ground from my controls ground using the isolator. However I am concerned if use a long USB, maybe 20 Ft., cable from the controls to my laptop it will act like a antenna. I want to create a fiber optic repeater for the USB . I have done some net research but there is a lot about protocol but how it works but not much on the hardware. I was hopping that D+ is something like computer to wave gen and D- is wave gen to computer. If the lines are bi directional than it will be harder. hopefully somebody knows or can point me in the right direction.
1417163066 195 FT167554 Dscn2208 50
1417163066 195 FT167554 Dscn2205 50
Fri Nov 28 2014, 09:31AM
mister_rf Registered Member #4465 Joined: Wed Apr 18 2012, 08:37AM
DIY optical isolation devices on the USB wires are difficult to obtain, because the signaling rate is 12 MHz, which is too high for cost-effective isolators. Also, you must carefully match the D+ and D– signals for propagation delay and skew—a difficult prospect when using optical isolators. In addition, the USB is bidirectional, whereas isolators are unidirectional, complicating the situation. Furthermore, in a peripheral with an integrated transceiver, the OE signal, which indicates direction, is inaccessible. More details here:
There are some commercial products designed for such applications. You need to search for USB Repeater. This will convert the USB signal into another signal, transmit it over some medium such Fiber Optic.
E.g. Link2
BigBad
Fri Nov 28 2014, 10:29AM
You could go bit serial on the optical link and stick arduinos at each end to act as muxes maybe, there's less optical hardware that way.
Arduinos talk USB anyway.
Dago
Fri Nov 28 2014, 10:30AM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
There are premade optical USB 3/2 cables off the shelf, no additional electronics needed: Link2
Fri Nov 28 2014, 10:47AM
@Dago
The above example is not suitable for total electrical isolation as the fiber-optic isolation. Those cables are using copper wires also. See the manufacturer disclaimer:
“This cable is designed to be compatible with self-powered devices using USB 3.0 and USB 2.0 interfaces. However, the USB-IF has not yet developed a specification for optical fiber transmission.” wink
Ash Small
Fri Nov 28 2014, 11:17AM
There is a trick you can do with Android devices to get them to connect to any USB device, but you need to provide a separate power supply for the USB device, as Andriod devices can't power external USB devices. I assume you'll need to do the same here.
You can get 'repeater' cables for USB (I use them for USB 2) when connecting devices more than a few meters apart. These effectively 'buffer' the data stream, then send it on to the next 'repeater'. I imagine the best place to put the fibre optics may be between two of these 'repeater' units.
Maybe others will have different suggestions?
Fri Nov 28 2014, 12:06PM
If it were me, I would use a Toslink cable from my laptop's optical audio output, to an audio DAC inside the coil. Then draw the ramp waveform in an audio editor like Audacity. Stereo, so one channel for the enable signal and the other for the ramp.
