  • Guests: 55
Directing lightning to hit where you want? Could be easier than you expect.
ConKbot of Doom
Thu Oct 23 2014, 03:03AM Print
Just found this :
from the same guys that did the recent video blasting away with a magentron in the open air at various things. Turn on closed captioning, (looks like they actually provided english subs, rather then a voice to text and automatic translation)
As far as I can tell, they have the kite in the air, anchored to the ground but with a thin wire running to the TV anode to give it a high voltage charge, and successfully get lightning to strike, run down the wire and blow out the TV. impressive that the battery can be scorched and blistered with only a few milliseconds of exposure. Really puts the power in perspective.
Thu Oct 23 2014, 03:42AM
Literally playing with lightning, that guy has a deathwish but by god if that isn't awesome.
Alex M
Thu Oct 23 2014, 09:58AM
That is amazing. Capacitor bank of the future anyone?
They have an interesting video of them playing on train tracks here Link2 and charging a phone from the rails. Does anyone know what that pulsating signal is for?
Artlav
Thu Oct 23 2014, 04:03PM
Artlav Registered Member #8120 Joined: Thu Nov 15 2012, 06:06PM
I wonder how much this was due to the voltage on the kite, and how much due to luck.
The air is positively charged, and the ground is negative, so adding a positive charge to the wire should have repelled the lightning, not attracted it, no?
At least, in a brute-force approximation, perhaps there are some complications.
ConKbot of Doom wrote ...
That's A LOT of ultraviolet. :)
Alex M wrote ...
My guess will be train detection, i.e. for automatic crossings - the wheels will be a low impedance path between the rails.
Thus, detecting where the train is should be possible by timing (or by measuring resistance at a certain point near the crossing?).
Nucleophobe
Thu Oct 23 2014, 04:53PM
Nucleophobe Registered Member #108 Joined: Thu Feb 09 2006, 11:44PM
Artlav wrote ...
Possible they had a negative charge on the wire?
I was expecting this to be fake about as much as I expected the Avengers 2 trailer that leaked yesterday to be. Now looks like maybe both are real, what has happened to the internet?
2Spoons
Thu Oct 23 2014, 09:06PM
localised ionisation. The same reason electric fences seem to attract lightning.
Sat Oct 25 2014, 06:11PM
Alex M wrote ...
Instead of a can crusher you could make a barrel crusher!
Sat Oct 25 2014, 06:23PM
Nik wrote ...
Alex M wrote ...
I really really really want to see that be done now... doubt it would be too hard or dangerous if you did it all remotely. Problem is getting the lighning to strike when you want it and where you want it. You might set up the rig and there isn't lightning for 10 months.
Sat Oct 25 2014, 11:55PM
Tom, there's a whole bunch of literature about induced lightning strikes with rocket lines and so on, way back to Benjamin Franklin and his keys.
Don't get yourself zapped. :) X
Sun Oct 26 2014, 01:12AM
Proud Mary wrote ...
Well i shan't be doing it. i live in a town and i rarely ever see lightning and its never close to us, haha.
I think it could be done with a load of copper piping around a drum going directly to ground with a large antenna sticking up from the end of the wire.... would be very interested in seeing such results.
