  • Guests: 99
Ian (37)
Lucas (40)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
HVHF Bobbins
Thu Sept 18 2014, 09:09AM
Old microwave transformers of the SMPS variety typically have monster cores.
The board is usually discarded whole because the IGBT normally commits smokeku when the transformer fails, sometimes the primary winding breaks but I have seen one secondary ground fail open circuit.
If you want even MORE ferrite, find a dead or smashed induction cooker, these can be repurposed into core stacks.
Thu Sept 18 2014, 04:16PM
Haha, i already got the ferrite. and my ferrite is much bigger, (did you read the rest of the thread?)
Thu Sept 18 2014, 06:18PM
We will both be core temperature limited, so getting started will let Thomas estimate heat load.
Tony Matt
Fri Sept 19 2014, 11:11PM
Hi !
Interesting, maybe planar geometry may be aplied in conventiona Fe-Si cores...
