  • Guests: 54
kywalda (63)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
Superconducting Higgs
Sun Sept 07 2014, 11:15PM Print
The implications here are that if a system could be designed to enhance this effect, it might be possible to generate gravitational effects using a relatively simple device.
The experiment uses a Type 1 (Cooper pair) superconductor niobium nitride (NbN) exposed to light pulses, causing the photons to behave as if they have mass.
It is possible that magnesium diboride (MgB2) as it superconducts near 40K and the laser pulse frequency and amplitude controlled by a resonant circuit linked to an accelerometer would be enough to see detectable gravity like effects within the superconductor, and possibly gravitational waves on a local scale.
-A
Mon Sept 08 2014, 05:32AM
The beginnings of the warp drive? Sounds interesting!
Mon Sept 08 2014, 06:38AM
Hope so, we need a backup plan in case Dinosaur Killer Mark 2 is en route.
I have some ideas if you are interested, my email is andre atp lanoe dpot net
demunge email and remove p's to email
EDIT: Link2
Daedronus
Mon Sept 08 2014, 09:02AM
Dinosaur Killer Mark 2 is not a question of if, only of when.
