  • Guests: 38
Mathias (42)
slash128v6 (53)
02/01 Barry (71)
02/01 Snowcat (38)
02/01 wylie (44)
Looking for a PWM (TL494-based) circuit for magnetic levitation that is simple and can support 0.6Kg
tarakan2
Mon Aug 18 2014, 12:28AM Print
tarakan2 Registered Member #3859 Joined: Sun May 01 2011, 03:47PM
I am looking for a good TL494 - based circuit that can levitate an object that weighs 600 gramms, with a window of homeostasys of about 10mm and is driven by PWM. Hopefully a circuit that uses an optical feedback and not magnetic.
I have seen this circuit:
Circuit
and this
Hall Effect Levitator Circuit
Maybe there is a cross between the two. I really like the idea of TL494 and I read a lot about this IC chip.
I don't want to deal with the Hall Sensor feedback because it is rather hard to adjust that window where I can hook my levitating load and it will neither fall, nor attach to the electromagnet core.
I am not confident enough in my electronics skills to develop that stage that feeds the analog signal to the TL494 from the phototransistors and the diode. I want to copy-cat the circuit somewhere.
Thank you.
I am ordering electronic parts and this is why I am asking a lot of questions.
I want to build a cheap torque balance that I can use in my experiments with physics and I want magnetic levitation to serve as the bearing.
tarakan2
Thu Aug 21 2014, 05:51AM
Would a circuit like this keep the MOSFET half-open? I want to work with big currents so I would rather build a circuit that either opens or closes the semiconductor.
Circuit from here may work: Link2
but I don't understand what I should feed into it.
It is described with words how to build the stage
Any suggestions?
I am thinking about using several MOSFETs in parallel and employing rectified mains to drive a large electromagnet to get higher levitation capacity.
Has anyone seen any PWM phototransistor ciruits?
How can I modify the bottom circuit to use an optical feedback?
Was this ever build?
I know it is has mistakes in it. I read that forum.
Thanks.
BigBad
Thu Aug 21 2014, 08:52PM
You shouldn't need more than one MOSFET; they're very powerful individually, and can carry ~40 amps at hundreds of volts, around 4kVA.
A few hundred turns at a few tens of amps should be fine.
tarakan2
Sat Aug 23 2014, 10:11PM
I am planning on combining those two circuits because I don't want Hall Sensor in my project and I want PWM to drive the MOSFET.
So here is my circuit for driving PIN 1, the input of TL494.
How do I find out the input resistance or impendance of pin 1 of TL494?
Is it equal to 12V divided by the input bias current of 0.2uA?
My simulation doesn't work for some reason I cannot explain. Node 9017 doesn't exist in my circuit.
Can this circuit work with two 20mA phototransistors? Link2
Thank you.
1408831863 3859 FT165429 Untitled
Th is works, but what output voltage range do I need for TL494?
2 Lm358 To Tl494
