  • Guests: 176
01/12 RoV IW3IPD (63)
Voltage Multiplier Problem
Dragon64
Thu Aug 07 2014, 03:31AM Print
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
I recently replaced the flyback on my voltage multiplier but the output seems to be almost nothing (Less than 1mm discharge as seen in this video)
I've tested the ZVS driver which seemed to be working fine although I am unable to test the output frequency because of a lack of oscilloscope. Also checked both the capacitors and diodes for the multiplier but all of them are in working conditions.
Here is the output of the ZVS driver itself without the multiplier.
The 6 stage multiplier should be able to produce a minimum of 40+ kV (As it did previously with my older ZVS/flyback combo. Assuming that the change in the zvs driver changed the output frequency (decreased), it should still charge up to several kV though with a much larger Vripple but since it isn't, I'm at a loss to what the problem could be.
Here's the schematic
And some pictures the multiplier
Any help to problem solve this multiplier would be greatly appreciated smile
Sigurthr
Thu Aug 07 2014, 04:17AM
I doubt there is an issue with the multiplier; just the application of it. Most modern flybacks are DC output (integral diodes), and voltage multipliers work on AC output.
Dragon64
Thu Aug 07 2014, 04:48AM
Sigurthr wrote ...
The flyback that I used is a AC old disc style flyback with no internal or external diodes.
In fact, here's a picture of it out of the mineral oil
1387561806 1438 FT0 Fb2
GrantX
Fri Aug 08 2014, 07:01AM
Hmm. Just to clear things up with regards to the photo of the multiplier: The red wire on the right-hand side is grounded (based on the connection of diodes and caps), the yellow wire is AC input and the lone wire on the left is the HVDC output, correct?
Honestly, I don't know, I'm extremely tired at the moment. During operation does the ZVS circuit draw a lot of current when the multiplier is shorted (close to the amount drawn when the flyback alone is shorted), or does it sit near it's idle open circuit current?
Dragon64
Sun Aug 10 2014, 02:19AM
GrantX wrote ...
Yup, the red wire is grounded and the yellow is the hot.
Here's the data for various operating conditions
Voltage Multiplier (not shorted) - 30.4W
GFDUTfp
Voltage Multiplier (shorted) - 24.9W
5ljiHmj
ZVS Driver Idle (Disconnected from multiplier) - 18.7W
LbuSzJe
ZVS Driver (Maximum arc drawn) - 236.4W
KkG6jaR
Sun Aug 10 2014, 10:03AM
I know you said that you tested all of the diodes and capacitors, but it sounds like one of them is bad. Maybe it tests OK with a meter but breaks down under high voltage.
Dragon64
Mon Aug 11 2014, 06:57AM
Steve Conner wrote ...
Hmm, you were right. I tested each diode and capacitors again but in high voltage conditions and found one capacitor at the foot of the multiplier to be shorted.
After replacing it, I managed to get the old sparks I used to get however another capacitor at the foot of the high voltage input shorted out a few second after (arcing with a resistive load). Seems like these Chinese caps cannot hold up to the output of the flyback.
Mon Aug 11 2014, 11:21AM
Generally, operation of a C&W without a matched load is likely to lead to trouble.
Mon Aug 11 2014, 01:11PM
Pulling arcs off the output is about the worst thing you can do. The sudden short circuits cause violent oscillations that put a lot of stress on the diodes and capacitors.
