  • Guests: 23
Mathias (42)
slash128v6 (53)
02/01 Barry (71)
02/01 Snowcat (38)
02/01 wylie (44)
Another dumb question - approximating frequency with oscilloscope.
tarakan2
Tue Aug 05 2014, 07:26AM Print
tarakan2 Registered Member #3859 Joined: Sun May 01 2011, 03:47PM
Is approximate Frequency of the signal =
(10^[Power of the Dial Setting] * Multiple on the Dial) / 2*[waveform length in centimeters]
Power of the dial setting as in x*10^-n = prefix*(x)
Centi n= 1
Centi n= 2
Milli n= 3
Micro n= 6
Nano n= 9
Pico n= 12
(or 1/10^-n)
So if I have a dial set to 100 microseconds / centimeter and the waveform takes about 1.5 centimeters on the screen,
then the input signal frequency is around 3333.3Hz?
Thank you.
Tue Aug 05 2014, 07:57AM
i think your complicating things.
typically were taught : Hz = 1/t
tarakan2 wrote ...
Thank you.
at 100 uS per cm then,
1.5cm x 100us = 150uS
so, 1 / 0.00015 S = 6666 Hz
others should cjheck im about to sleeeeeeeeeeeeeeeep
Dr. Slack
Tue Aug 05 2014, 08:08AM
It's easier to take it a step at a time.
If the dial is set to 100uS/cm, and the waveform takes 1.5cms, then the period is about 150uS.
If the period is roughly 150uS, then the frequency is somewhere in the region of 7kHz.
Note that I've presented the answer to the number of decimal places appropriate for reading frequency off a scope.
Tue Aug 05 2014, 08:13AM
i believe there are only two sig figs so 6.6 khz ...
Sat Aug 09 2014, 10:45AM
Hiya Tara,
don't forget you can build yourself a nifty 1MHz test oscillator for a couple of quid, so you can really see what is going on with your 'scope.
