  • Guests: 45
Mathias (42)
slash128v6 (53)
02/01 Barry (71)
02/01 Snowcat (38)
02/01 wylie (44)
130V push-pull PWM generator
Linas
Sun Aug 03 2014, 10:18AM Print
Hello, i ran into problem, i need to generate ramp up and ramp down signal for pjezo motors. problem is with simple 150V opamp and emitter follower, it does work, but since power consumption is around 15W, all that goes to heat, and i don't what that (even with heat sink, it goes very hot very fast)
I need something like IR2110, but it must operate at high pwm signal frequency with 100% duty cycle capability. At also should have separate charge pump, for high side mosfet, so i don't have to make isolated power supply
Ideal part would be LT1336, but it must operate at 130V half bridge voltage. Any one knows PWM controller that can do it ?
1407061178 1143 FT165179 3112
