  • Guests: 48
Mathias (42)
slash128v6 (53)
02/01 Barry (71)
02/01 Snowcat (38)
02/01 wylie (44)
What is this part?
Inducktion
Sat Aug 02 2014, 11:23PM Print
Found it while taking apart a laptop...
Is it just a microphone or something?
20140802 181337
20140802 181346
Carbon_Rod
Sun Aug 03 2014, 12:46AM
If you have a buspirate or i2c scanner... I'd suggest looking for active addresses.
I'd wager it is likely some sort of environmental monitoring chip like a humidity sensor etc.
Most microphones are analog as they connect to a sound-card chip.
Inducktion
Sun Aug 03 2014, 02:38AM
I don't do much digital work... So I have no clue how I'd go about doing anything with it.
Carbon_Rod
Sun Aug 03 2014, 03:29AM
If you peel back the rubber grommet, an actual part number should be printed on the device.
The bus pirate v3.6 is a good $30 investment, as it runs over a virtual serial port:
Example:
Open Logic Sniffer Setup:
You could look at the sniffer log to characterize the protocol while running. Then look-up the unique manufacturer address, or dump the data from device memory for further analysis.
Do you have a photo of the board plug it came from?
