  • Guests: 51
Matching a LT1253-based amplifier and two MAX4420. Two ready-designed circuits.
tarakan2
Thu Jul 24 2014, 09:08PM Print
tarakan2 Registered Member #3859 Joined: Sun May 01 2011, 03:47PM
I am trying to drive this circuit:
with a signal output from a wide-band amplifier circuit:
Datasheet for MAX4420 - Link2
Datasheet for LT1253 - Link2
I need to obtain an output and an inverted output from my amp to drive the two ICs, as I understand.
Should I replace two MAX4420 ICs with UCC37321 and UCC37322 :
Following this analogy:
or should I connect my circuit so one MAX4420 receives an input from a pullup resistor, connected to the 12VDC rail and another one receives input from a pulldown resistor, connected to the ground?
A single output pin should drive them so a pair of diodes may also be required if I am correct.
Thank you.
Vladimir.
Fri Jul 25 2014, 05:28AM
The TL494 IC have two output pins that work in push-pull mode in my schematic you linked to. Therefore I used two non-inverted MOSFET driver ICs.
If you only have one output, you could use the MAX4420/MAX4429 or UCC37321/UCC37322.
You could also add a 7414 hex inverter schmitt trigger to invert your signal if you use two of the same MOSFET driver ICs.
tarakan2
Sat Jul 26 2014, 10:22PM
Mads Barnkob wrote ...
I understood that. In my case I have only one output of a square wave generator.
What is the minimum and maximum frequency your circuit can drive the flyback transformer under?
I am building an experimental generator that will be able to output a wide range of frequencies. I am building it in modules. What is the frequency range of your circuits? Thank you. --Vladimir.
Sigurthr
Sun Jul 27 2014, 06:43AM
The UCC chips are good to 1.25MHz depending on the gate drive current required (gate capacitance and GDT impedance) and if you can heatsink them well. Without heatsink and under heavy load I wouldn't expect more than about 500KHz.
tarakan2
Sun Jul 27 2014, 04:14PM
tarakan2
Sun Jul 27 2014, 06:41PM
I really like how you use a timer to enable the impulse and an antenna-driven circuit to position it in the right place within Tesla Coil oscillation.
tarakan2
Sat Sept 06 2014, 05:56AM
What ferrite core should I use to make a transformer that couples the MOSFET gates to driver ICs?
There are many ferrites out there.
Sat Sept 06 2014, 12:37PM
You most probably want a core made from a high permeability ferrite material like Fair-Rite type 78 or Ferroxcube 3C90. Hard to say though as you haven't specified what frequency the thing will be running at.
Micrometals only make iron powder cores.
tarakan2
Fri Oct 10 2014, 09:47PM
I found this:
A guide on how to design Gate Drive transformers.
I wish I could buy cheaper cores without brand names.
Shrad
Sun Oct 12 2014, 06:05AM
there should be some on ebay
did you have a look at cheap DDS modules off ebay? most of them are OK to some megahertz, and offer arbitrary waveform generation via serial or parallel input, which enbable you to use any arduino or PIC or even computer to get a signal at a given duty cycle and frequency
