  • Guests: 23
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
AC resistance of a coil
Mon Jun 30 2014, 08:48PM Print
Hi guys,
do you know of any calculator or formula which can calculate the AC resistance (ESR) of a solid conductor coil at a given frequency? Single-layer coil calculations would be enough for me.
I know how to calculate the resistance of a wire based on the skin effect, but the proximity effect plays a role as well in a coil and I don't know how to calculate that.
Thanks for replies,
Jan
2Spoons
Mon Jun 30 2014, 10:27PM
simplest way is to use something like FEMM, which will model displacement current and give you resistance directly. In my research i've found the current distribution is strongly affected by overall geometry, including the geometry of ferromagnetic materials nearby.
Tue Jul 01 2014, 12:36AM
I haven't a formula, just an approximation;
T.C. - type secondaries that I have measured come out at about 2.5x dc resistance
when skin-depth = 1/3 wire diameter.
teravolt
Tue Jul 01 2014, 02:44AM
I usually approach it like this
in my college text book Q=XL/r r is the ac resistance in a inductor at resonance in a resonant circuit
XL=2*PI*F*L
2Spoons
Tue Jul 01 2014, 03:19AM
I've attached an image showing current distribution in a coil at 100kHz (part of my research at work). This is a 2.5D model - what you see is half the cross -section of a cylindrical coil. I just wanted to show the kind of complexity that results from the field geometry - this is why i suggested using a mag simulator to get AC resistance.
This image came from the Ansys Maxwell software i use, which is horribly expensive, but FEMM will do as good a job in this situation - and its free.
1404184766 2939 FT164370 Current Displacement
Tue Jul 01 2014, 02:26PM
OK thanks for the input. I guess I was looking for some empirical type relationship, but it looks there is none...
