  • Guests: 62
Powerline Transformer Question
nrhoades
Mon Jun 30 2014, 02:00PM Print
nrhoades Registered Member #610 Joined: Wed Mar 28 2007, 09:44PM
For those of you out there who own a powerline transformer: I'm interested in knowing what the output impedance is (as seen from the house line) for 1kHz to 1MHz, specifically 40kHz.
Anyone care to take a measurement for me?
Mon Jun 30 2014, 06:02PM
I guess it will be large; why do you want to know?
The "standard mains impedance" for approximate calculations here in Europe is R=0.4 ohm, L=600 uH. It varies wildly, depending on how far you are from the transformer, what type of power line is used (cable or overhead) etc.
teravolt
Mon Jun 30 2014, 07:22PM
usually those are iron core and won't run out side of there frequency ratings. you could make a h-bridge and just try a small iron core transformer and see what happens. zilipoper has done stuff like that. put his name in the search column
nrhoades
Mon Jun 30 2014, 08:51PM
I want to make a circuit that can remember which outlet it is plugged into based on the impedance it sees. I'll be using a lock in amp with averaging so it'll be pretty accurate I think. Just trying to get an idea for what I'll be expecting to measure.
teravolt
Mon Jun 30 2014, 09:55PM
do you plan to detect the current in each socket? you could use ferrite torides to make the measurements
Mon Jun 30 2014, 11:07PM
As Dr. Dark Current said,
the impedance of a mains supply at RF frequencies
can vary widely depending on many details of building wiring.
That presents a challenge for standardized testing of equipment for conducted EMI.
The relevant standards (such as those by FCC and TUV) call for a special filter called a LISN between the mains and the equipment under test. I once made a 50 amp three-phase LISN.
You might find some useful numbers by searching the Internet for articles about LISN (Line Impedance Stabilization Network) applications. Please let us know what you turn up.
Newton Brawn
Tue Jul 01 2014, 01:39AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
nrhoads'
Let us know wath is the nominal voltage of the line Vs and maximum current Im that can be suppied.., and frequency Fs.
nrhoades
Tue Jul 01 2014, 03:18AM
lets assume that I am only interested in 40 kHz, with a very tight filter around that. I'll use a transformer to couple to the outlet with a blocking capacitor, so the resonant peak is at 40 kHz.
Im assuming that it'll be pretty noisy. Looking for signal max to be about 1Vpk, 100mA max.
I will be filtering out DC (well, 60Hz), so I don't care about the traditional power present at the outlet.
I'll look up LISNs
Tue Jul 01 2014, 04:40AM
I found this reference which talks (broadly) about measured impedance of actual power lines (including, presumably, the final transformer): Link2
This one has a chart of impedance looking into the LISN. The 50 ohm value at high frequency might be there for practicality, rather than being representative of typical mains: Link2
I would worry that with a single parametric measurement, outlets on different circuits might have the same reading.
Have you considered measuring |Z| (or vector Z) at more than one frequency?
Or making a TDR set to get a time-domain view of the cable plant?
What frequencies are used by those controllers that use "out of band" signals on power wires?
The choice must have considered transmission characteristics and the noise environment.
Newton Brawn
Tue Jul 01 2014, 03:14PM
Assuming that the nominal voltage of your outlet be 115 V
Assuminng that the max current be 15A
Assuming that the freq be 60 Hz,
And
You measure no load voltge at outlet as 117V
and
you add a 10 ohm resistor in the outlet and get 112 volts
and a current of 11.2 A.
The voltage drop will be 117-112 = 5.0volts
the impedance of line (60Hz) will be E/I = 5.0/11.2 = 0.446 ohms.
Assuming that the X/R = 1 at 60Hz
X = 0.315 ohms
R = 0.315 ohms
Now, for 40kHz,
Freq ratio = 40000/60 = 667
Then, for 40kHz,
X= 667 x 0.315 = 210 ohms
R= 1 x 0.315 = 0.315 ohms
Z= 0.315 + J210 = 210 ohms
The exac value of X/R may be determined by a inductor of 10 ohm,s 10A.
