  • Guests: 50
*Tiny* Telsa Coils
loneoceans
Tue May 27 2014, 05:59PM Print
Hi Everyone,
I recently dug up some old photographs of a tiny Tesla Coil I built back in 2004/2005, almost 10 years ago. I recall that there was some sort of competition going on back in the days on the old white then dark-blue 4hv forum for the smallest tesla coil you could make. I can't seem to access the archives, but I finally got a page up on my tiny coil. It has a 5mm diameter secondary (that's less than 0.2"!) and made sparks just around 10mm. :) I also *finally* did a writeup on it here: Link2
RIMG1284 Small
Here's me winding the tiny coil with wire so thin it broke once when I was trying to wind it.
RIMG2061 Small
And the coil making sparks twice the diameter of the secondary (the secondary looks fatter than 5mm because it has clear heat-shrink over it)
So my question to everyone: what's the smallest Tesla Coil you've ever made? amazed
Artlav
Wed May 28 2014, 07:57AM
Artlav Registered Member #8120 Joined: Thu Nov 15 2012, 06:06PM
Does this 3D printed one qualify?
For a real tesla coil, the smallest one i made was about 20cm tall, on top of a 10x10x10 cm box containing the guts.
Variable spark gap, ran on a taser transformer powered by 4 AA batteries, could make 100 1cm sparks a second, or 2-3 10 cm ones a seconds, depending on how wide you made the spark gap.
No pictures at the moment, since it was a birthday present to my nephew.
I like making small scale stuff - it feels like more of a challenge.
loneoceans
Thu May 29 2014, 06:22PM
Artlav wrote ...
Artlav that looks really nice! I agree with you that building small coils is a slightly different challenge in itself. I've recently been working on some small table-top sized projects which are easy to carry around in a small bag.
On another note, is anyone able to access the Archives from the 4hv main menu on the top left? I just get an error message saying: Warning: mysql_connect(): Access denied for user 'a4hvorg_enigma'@'localhost' . I recall some very nice tiny coils in that tiny tesla coil thread back in the day.
TwirlyWhirly555
Thu May 29 2014, 06:50PM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Very nice :D ,
I do like small coils , My smallest was a 800Khz SSTC with a 2" x 2.8" secondary that pushed 9 inch arcs in pulsed operation .
Wed Jun 04 2014, 02:34PM
Tesla coil "Magic Wand" is doable if piezo transformers are used to generate the HV for the primary.
I'd look into using the beam triodes ie 6C23 as these are pretty powerful for their size and can handle 20+ KV with only minimal shielding.
