  • Guests: 54
First DRSSTC questions
waicool20
Tue May 27 2014, 02:29PM Print
waicool20 Registered Member #40981 Joined: Thu Nov 21 2013, 08:40AM
Hello everybody at 4hv! New here~
So I've been planning to build a DRSSTC and was wondering if this IGBT would work: FGH80N60FDTU I have a lot lying around and i saw that they have similar specs compared to the other popular IGBTs
And i also want to know what or how should i find out the voltage rating should i get for the Tank Caps
Btw I'm only in highschool so yeah I'm kind of semi experienced in this stuff only,so help would be appreciated
Expected specs:
0.2uF MMC
4 inch OD secondary coil 30 inches tall
8 inch OD primary tapped at 5~7 turns
Resonance at 130 khz
Using custom layout Steve Wards 2.0 driver
Self made interrupter
Runs on 220v mains directly
Full bridge design
Mostly copied from schematics online and changed to meet my needs ~
waicool20
Sat May 31 2014, 05:38AM
Any help pls? I could post some pics if that would help out...
Sigurthr
Sat May 31 2014, 05:55AM
The capacitor voltage rating has to be determined by the maximum ringup voltage expected in the primary, which is a factor of the burst length in cycles and whether your inverter uses a full or half bridge. You have to choose a burst length that won't exceed your maximum pulse current or cap voltage, and determining that mathematically isn't easy.
I started a few threads, emailed a lot of experienced builders, and spent a month trying to nail down a procedure for the math but ended up largely unfinished. I got close to a firm formula but couldn't confirm it since I don't have a DSO (only an analog CRO).
If you don't get anywhere let me know and I'll try to dig up my work on the subject and pass it on to you.
I suspect that most builders just go with rule of thumb known good parameters, but surely someone has a finished mathematical method of choosing Vcap and Burst length based on available Vbus and Iocd!!
Sat May 31 2014, 11:46AM
The day someone comes up with an accurate model of streamer loading, I'll publish that method. smile Until then, you might like to try the following rules of thumb:
Dimensions of coil: Same rules as classic sparkgap coils apply, but aim for a "stubbier" secondary as this helps achieve better coupling and a lower resonant frequency. Smaller DRSSTCs need somewhat more turns than a sparkgap coil of the same size, otherwise the frequency gets too high for efficient operation of IGBTs. Try to keep it below 200kHz for 600V discrete IGBTs and 100kHz for 1200V bricks.
Secondary impedance = sqrt(Lsec/Csec) = 50k to 100k (JavaTC will tell you this) In small coils you will need to compromise between too high secondary impedance and too high frequency. Beginners should probably go for lower frequency and higher impedance.
Primary impedance = sqrt(Lpri/Cpri) = 10 to 20 times (4/pi)*(Vbus/Iocd)
The above rule fixes Lpri/Cpri. Also, the primary must resonate at the same frequency as the secondary and this fixes Lpri*Cpri. So, you have two equations from which you can calculate the two unknowns, Lpri and Cpri. Allow about 20% more primary inductance so you can detune to compensate streamer loading.
Tank capacitor voltage rating = 10*Vbus (approx) or Iocd/(2*pi*fres*Cpri) (more accurate)
Burst length = 150 to 300us
Coupling = 0.15 to 0.25
Anywhere within this range seems to give a good performing DRSSTC. Higher values of coupling tend to suit lower primary and secondary impedances, and vice versa.
Sigurthr
Sun Jun 01 2014, 12:09AM
Steve Conner wrote ...
What about a formula for an unloaded coil? This would give you an upper end worst case scenario you could use to determine parts ratings. If there is no loading the you can determine the maximum voltage the cap has to withstand before the OCD kicks in to limit current.
How does burst length factor into that formula? In other words, how would you modify the formula to allow much longer bursts, perhaps 500-750uS? Burst length is significant in terms of half cycles so fres would need to enter in somewhere as well. This is the root of the problem I was trying to address in my previous work.
Btw, thanks a ton for the rules of thumb above, they're invaluable!
waicool20
Sun Jun 01 2014, 01:07AM
IMG 20140514 173611
Well heres a pic of my coil, i know it might be a little crude especially the primary coil. But I want it functioning more than i want it looking good since its my first drsstc :D so what do ya guys think?
And also what do you think of this IGBT FGH80N60FDTU
Link to datasheet: Link2
Further pics may take a as Im having exams
Sigurthr
Sun Jun 01 2014, 01:10AM
Looks like a good start!
I'd avoid wood near the primary though, it becomes a conductor at high voltages. You're one primary strike away from a carbon path that'll destroy the entire coil if you use wooden supports.
waicool20
Sun Jun 01 2014, 04:52AM
Ok I'll change it to acrylic supports then thx for the feedback and also I've been wondering Steve Wards 2.0 Driver has only 1 output do I connect all 4 GDTs to it as im running a full bridge cuz ive only seen schematics that connect 2 for a half bridge
And I tell you it wasn't a good start at all XD the coil took weeks to wind and paint because I had so little time to work on it every week the lacquer on it isn't even sanded down. It might look good in the photo but it really is ugly ;)
I'll post pics of the driver later
waicool20
Sun Jun 01 2014, 05:24AM
IMG 20140520 164852 1
IMG 20140509 201403
Here's the driver based on Steve Wards 2.0 Universal Driver I made into a single sided board with unfortunately a lot of jumper wires, I haven't scoped it yet so I don't know how well it'll do but I'm sure the power supply rails are at good voltages and stable ,I'm just afraid the 90° PCB traces will mess up the signal...sigh~ I didn't realize it till i finished the board...
Sun Jun 01 2014, 08:46AM
wrote ...
The formula I gave above for tank cap voltage rating covers this case.
wrote ...
Because we don't have an accurate streamer model, we don't know in any detail how the streamer load develops with increasing burst length. So I assumed the streamer load to be unchanging with burst length, and that is why burst length doesn't appear in the formulas.
In practice, we know that the load gets heavier as the streamer develops. This means that a coil designed for long bursts should have a somewhat higher impedance primary and lower impedance secondary: the magic number in the primary impedance formula I gave should be nearer 20 than 10, and the secondary impedance nearer 50k than 100k. (Or maybe even lower than 50k as you will find in QCW coils)
