  • Guests: 80
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Growth Model Based on the Kardashev Scale
Chip Fixes
Fri May 02 2014, 07:04PM Print
Um here's my writeup so far:
1399054683 3781 FT0 Court
I'm basically using the Kardashev scale to predict what year we will be able to maximize our consumption of Earth's energy, and thus start harvesting the sun's energy.
Unfortunately, there are only 20 known data points and I'm trying to predict the slope of several hundred points, so I made 3 graphs with the three *best* trendlines. My graphs also omit the first two data points (1980, 1981) because they are outliers.
1399056365 3781 FT0 Court
The graphs are K vs Time where x = 0 is 1981 and x = 1 is 1982 (the x axis is arbitrary since the x-intercept is unknown).
1: Exponential trendline
2: Linear trendline
3: Polynomial trendline with order 2
According to the R^2, the polynomial is the best fit, but I'm thinking the most accurate trendline will be some sort of combination between all three trendlines, maybe an average? (Although my gut tells me the exponential trendline is the most accurate of the three)
I graphed all three on the x-y plane in using WolframAlpha and got: (WolframAlpha raw data: Link2 )
1399057076 3781 FT0 Court
Where y=1 is the kardashev value of 1 which equates to the maximum Earth energy consumption of 10^16 watts.
I doubt any of the graphs are accurate past y = 0.9 because at that point I suspect the graph will turn into a polynomial of order 3 for a short period of time while Earth's civilization goes through a new 'Industrial Revolution' of sorts. From Y = 0.9 to Y = 1.1 I suspect the civilization will start building a Dyson sphere or something similar so they can start harvesting the energy of entire stars in space (beginning with our sun?).
Please discuss, and let me know if you have any suggestions or anything.
EDIT: I am planning on comparing the world population graph to my graphs at some point soon. Maybe I could use the result to make an accurate estimate of when the Earth was a Type 0 civilization? I am also curious to see how the Industrial Revolution affected everything.
Fri May 02 2014, 11:46PM
when we talk about all this theoretical Dyson sphere stuff, we account for solar cycles right? the 11, year cycle (for our case) we know of right?
and do we know if there are other solar cycles? perhaps 72 and/or 400 years too?
Carbon_Rod
Sat May 03 2014, 02:22AM
All life on earth only retains well under 2% of solar energy input into the system.
Change this and you will slowly destroy most ecosystems.
Sat May 03 2014, 07:31AM
Hmm.
Has it occurred to the Dyson sphere folks that even a high radiation star might still be useable IF all that energy is harvested and used for shielding the central equatorial regions?
Sun May 11 2014, 08:15AM
I'd like to think that as a civilization gets more advanced, the energy utilisation will plateau and then maybe even go down as they realise the environmental implications of it. There are more kinds of "advancement" than just hard science fiction.
