  • Guests: 97
01/12 RoV IW3IPD (63)
A model of electrons orbits around the nucleus using magnets and gears
Andy
Wed Apr 16 2014, 09:00AM Print
Thoughts?
1397766905 4266 FT1630 Images2
Link2, The neutrino has a 1/2 spin which could account for the gears in the system, rather than fixed, passing neutrinos could make a changing gear ratio sizes well still maintain the 720/180 spin.
Related
The theory would allow beta decay, through neutron spin, to interact with the electron
Semi related
Proton neutron charge exchange, with the spin/information exchange
Closely related
This interaction is the same as the one at left since a W+ going right to left is equivalent to a W- going left to right.
A neutron or proton can interact with a neutrino or antineutrino by the exchange of a Z0.
The theory also allows for signal cancellation, the outer magnetic will produce ac fields that can be canceled by other ac fields, producing a stable field, the system is designed for multable atoms interaction, but to test a single atom in vacuum(a single hydrogen atom with a electron, but as hydrogen is bonded to another hydrogen atom to form stable structure it would be diffcuilt to test), should change the spin of another with repeated measurement tests taken.
This theory is to try and explain electron clouds
1397871606 4266 FT1630 Electron Cloud2
, and that they might not be random, weather from other atom in close proximity that will change the 3d angle of the orbits, or neutrinos that will change the distance from the nucleus.
Wed Apr 16 2014, 09:55AM
" I don't know what physic force the gears would be "
a new sub-atomic particle .. 'gearons' ?
I think that your model would radiate an alternating magnetic field
so it cannot represent atomic structure.
(conservation of energy etc.)
Andy
Wed Apr 16 2014, 10:31AM
Thanks Sulaiman
I think I'll have to read up some more about the understand of atoms, was just a idea.
Found some links, its going to take a month or so to understand, but I think the above model might be different.
This below, was something the produce some strange patterns with data from measurement tools, about atoms. I thought it might be relevant.
4032.600098 = 1(g/1000.6642)*Ekg)*360
g = 9.80665m/sec
Ekg = 9.1093
4032.600098 1
2016.300049 2
1344.200073 3
1008.150024 4
806.520020 5
672.100037 6
576.085754 7
504.075012 8
448.066681 9
403.260010 10
366.600006 11
336.050018 12
310.200012 13
288.042877 14
268.839996 15
252.037506 16
237.211777 17
224.033340 18
212.242111 19
201.630005 20
192.028580 21
183.300003 22
175.330444 23
168.025009 24
161.304001 25
155.100006 26
149.355560 27
144.021439 28
139.055176 29
134.419998 30
130.083878 31
126.018753 32
122.200005 33
118.605888 34
115.217148 35
112.016670 36
108.989189 37
106.121056 38
103.400002 39
100.815002 40
98.356102 41
96.014290 42
93.781395 43
91.650002 44
89.613335 45
87.665222 46
85.800003 47
84.012505 48
82.297958 49
80.652000 50
79.070587 51
77.550003 52
76.086792 53
74.677780 54
73.320000 55
72.010719 56
70.747368 57
69.527588 58
68.349152 59
67.209999 60
66.108200 61
65.041939 62
64.009529 63
63.009377 64
62.040001 65
61.100002 66
60.188061 67
59.302944 68
58.443481 69
57.608574 70
56.797184 71
56.008335 72
55.241096 73
54.494595 74
53.768002 75
53.060528 76
52.371429 77
51.700001 78
51.045570 79
50.407501 80
49.785187 81
49.178051 82
48.585545 83
48.007145 84
47.442352 85
46.890697 86
46.351727 87
45.825001 88
45.310112 89
44.806667 90
44.314285 91
43.832611 92
43.361290 93
42.900002 94
42.448421 95
42.006252 96
41.573196 97
41.148979 98
40.733334 99
Andy
Sat Apr 19 2014, 02:09AM
Hi Sulaiman
I think this explains the
If radiation from the suns, produce a electric potential throughout the solar system, it could have kicked started the fluctuation.
Thoughts?
Sat Apr 19 2014, 07:10AM
Hmm. I think this sounds interesting.
The current consensus with superheavy atoms is that closed baryon shells ie doubly magic nuclei are much more stable against alpha decay due to the strong nuclear force but as a result are more prone to spontaneous fission.
The gear analogy is an interesting way to see this, however maybe weakly magnetic gears with small teeth would be a more accurate method?
See Link2 Warning: Nasty math with imaginary numbers
-A
Andy
Sat Apr 19 2014, 08:53AM
Hi Conundrum
I'm not sure about the inner structure of the nucleus and weather it forms some type of halbach array, so some magnetic s from some neutrons get canceled, just that overall it should make a dipole magnetic.
I'm assuming that neutrons might switch between electrons and back, like beta decay but without leaving the nucleus, maybe get hit from some sub particle, or electrons that get close to protons is the stable form and that neutron/protons are the unstable form.
confused
Don't know..
Thanks for the link.
Sat Apr 19 2014, 10:36AM
Hmm.. interesting analogy.
I did have a thought about alternate decay modes, the recent work with isotopic enhancement of HTSC suggests that in theory energy normally contributing to rapid decay could decouple to the electron shells and be converted to Cooper pairs, allowing for longer half life.
Andy
Sun Apr 20 2014, 01:06AM
With the Cooper pairs arrangement, if the orbit electrons went more to one side Link2 , it might change the magnetic field which is meant to be static(nucleus), and allow a neutron that is switching to a electron to escape from the otherside.
Found this link Link2, which should explain part of the electron/electron interaction, and will see if I can add the 780/180 spin, in theory all the electrons could be on one half side of the nucleus at some point in time, but will probable need another atom close by, say a oxygen atom to make O2. If firing electrons at the two atoms, changes the orbits there should be noticeable effects, one oxygen atom is 504.075012, the 0.075012 mutliped by 2 atoms, assumes that one of the atoms becomes a isotope which matches the O15(15.0030656(5))+- in isotopic mass with two electron that transfer between atoms, should make it have some effects of Beryllium(Be8) with 8.00530510, mass
Because of its low density and atomic mass, beryllium is relatively transparent to X-rays and other forms of ionizing radiation
Maybe this is away to test the theory, create a plasma discharge in 100% oxygen and see if it is more transparent to X-rays, assuming that the weight/mass of Oxygen will drop to that of Beryllium, while the neutrons chance to electrons then back.
Pushing the theory some what to its limits, but there's no reason in its bounds to say it can't
The 1000.6642, is meant to take into account orbits of electrons, the 1000 is made up of 1meter radius 1kg and 10m/sec(gravity rounded, some calculation added from coulomb force of electron), with the 0.6642 the sun-(Jupiter+Saturn+earth+gravity offset), assuming that spinning electrons makes artificial gravity, with the right side the correction offset from being in the same gravity field. Don't no the name of the maths foumla, but is like xor, two inputs one output, the overall data makes a scale that can change based on the distance from the very center of the nucleus to the electron, plus the degrees of rotation, and mass, assuming that small masses speed up larger masses, while large slow down smaller masses. Its why the Sun is in the equation, as the gravity field will effect the orbits of electrons.
Foumla is designed to butchered cheesey
Sun Apr 20 2014, 08:21AM
Will you guys quit trying to explain quantum phenomena in terms of classical intuition? tongue
Tue Apr 22 2014, 04:50AM
Fair enough.. still interesting though.
