  • Guests: 34
Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
Cap selection
Andy
Fri Apr 11 2014, 11:36PM Print
Hi all
I was wondering what would be the most value for money with the highest possible Farads.
Thanks
Ash Small
Sat Apr 12 2014, 10:40AM
If ESR isn't an issue, and if you don't need bi-polar capacitors, electrolytics will be the best value for money.
Andy
Sat Apr 12 2014, 10:59AM
Thanks
If the arc distance is 0.5mm with a multiplier of 2 for overhead would voltage range would be good?
Ash Small
Sat Apr 12 2014, 12:33PM
Well, "0.5mm arc distance*2" isn't a voltage rating, diodes will stop 'reverse voltage' and, as I don't really know what you're intending to use this for, I've no idea what values may be suitable.
Andy
Sat Apr 12 2014, 12:41PM
Ash Small
I'm still working out the details.
Thanks
Sat Apr 12 2014, 01:37PM
'Paschen's law' Link2
will give an approximation of voltage vs (arc length x Pressure) required
P.S.
be sure to have a large value resistor between the arc gap and the capacitor(s)
this will prevent all of the energy stored in the capacitor(s) instantly being dumped into the arc gap.
Andy
Sat Apr 12 2014, 01:45PM
Thanks Sulaiman
