  • Guests: 39
Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
Rare HV to LV converter
Antonio
Sat Apr 05 2014, 12:23AM
A simple rule about charging a capacitor through a resistor from a fixed voltage is that the resistor dissipates the same energy stored in the capacitor. It's possible to use an inductor and switches/diodes instead of the resistor, greatly improving the efficiency.
Microwatt
Wed Apr 09 2014, 08:59PM
howabout using a tesla coil backward? is it not posible to get 200 ac out and use a smps to get it down to 12vdc?
Antonio
Thu Apr 10 2014, 12:06AM
Microwatt wrote ...
This would work, but what to use as switch from the high-voltage supply to the top terminal of the Tesla coil? The switch would have to block twice the full voltage. A spark switch would waste half the energy or more. An inverted flyback converter is less bad, but again there is need of a switch blocking the full voltage.
Microwatt
Thu Apr 10 2014, 04:33PM
well the power wasted will make up for the high costs of SiC IGBT's you will need to use.
GammaRay
Fri Apr 11 2014, 02:25AM
GammaRay Registered Member #5323 Joined: Fri Jun 15 2012, 02:14PM
UPDATE:
I found a Buck converter I built years ago. I modified it with a gas filled spark arrestor (500v) on the input for S1, then connected the buck converter, through a 1M resistor to cap C2 charged to 1200v (the 1M input resistor not shown on the schematic). It worked, it down converted 1200v to around 5 volts on a load. However, I assume using a spark gap as a switch and a 1M input resistor is amazingly inefficient.
1397182762 5323 FT162126 Buck Schematic 20
Now that this approach shows some promise (at least at 1200v input), the question in my mind is exactly what switch to use as a replacement for the gas filled arrestor for use with this particular circuit considering that the switch could see voltages as high as 35kV. I remain appreciative of helpful suggestions.
Fri Apr 11 2014, 07:35AM
GammaRay, it looks to me that your circuit charges up C2 then transfers the energy to C1
... a current source / current limiting device would need to be used for repetitive operation
... bringing the problem back to charging a capacitor from the eht stage voltage
unfortunately the energy loss in a resistor charging a capacitor is equal to the capacitor stored energy
(never realised this before..neat)
applies only if the capacitor voltage is allowed to reach the charging voltage
which in this case would defeat the purpose.
So the energy dissipated in a series charging resistor
will be more than the energy transferred to the capacitor,
just didn't want a useful relationship misleading estimations.
I can't think of any practical converter, I'll be reading this thread with interest
only power grid eht dc / ac converter technology comes to mind.
Fri Apr 11 2014, 01:16PM
Ok, as resistors are out, how about an inductor, under oil, to limit current? The problem of the 'HV switch' still remains, and there will also be insulation issues to deal with.
Fri Apr 11 2014, 05:00PM
something like resonant charging could work efficiently
but the resonant capacitor per stage would be twice stage voltage
and I cant imagine how large an rsg for the whole system would be
- certainly lots of rotational energy!
Then there's the problem of the main capacitor voltage falling during discharge.
Fri Apr 11 2014, 05:04PM
Sulaiman wrote ...
So how about either a series mosfet string, or HV triode, and a variable inductor to deal with falling voltage. Just move the core out of the winding to reduce inductance?
EDIT: or place the inductor between the main bank and a much smaller capacitor, and then discharge the small one into your LV bank using an scr or similar. The inductance (if it were large enough) would prevent the main HV bank from discharging (I know this would need a BIG inductance, so maybe the above idea would be better)
Artlav
Sat Apr 12 2014, 01:04PM
Artlav Registered Member #8120 Joined: Thu Nov 15 2012, 06:06PM
Meanwhile, i kept wondering about the idea from my first reply - using a couple of HV triodes in a regular push-pull converter, and decided to try it out.
Somewhat unsurprisingly, it didn't work at all.
There was only 0.5V at the output, instead of expected 20V, with 1000V input.
Not sure if it will be a good idea to try it with 10-20KV.
The triodes are 6С20С i mentioned above, rated up to 25KV, and 1 mA.
So, what am a doing wrong here?
Here is the schematic - a 555 PWM with an inverter driving a couple of triodes between -12 and +6, with a tapped transformer attached:
1397307415 8120 FT162126 Sch Hv
And the construction:
1397307415 8120 FT162126 Build Hv
