  • Guests: 39
Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
Rare HV to LV converter
Antonio
Thu Apr 03 2014, 12:12AM
Machines like this were studied in the past. The first idea was probably the "rheostatic machine" of Gaston Planté, that could charge a bank of capacitors in parallel and discharge them in series, or the opposite. Only the switches must rotate, but it's of course possible to rotate the capacitors too. I remember seing a version on Youtube, and have somewhere documents describing a similar idea. With adequate inductors, diodes, and switches efficient commutation for the charging and discharging phases can probably be obtained. A problem is how to make this work automously, without someone turning a crank.
Andy
Thu Apr 03 2014, 05:01AM
GammaRay
Don't know about this, but the transformer can make voltage pulses, with a type of buck converter to level out the pulse to a low voltage level
1396501316 4266 FT162126 Voltage
Yandersen
Thu Apr 03 2014, 10:24AM
GammaRay, may I suspect that the demand of HV-LV transformation arised from the plan of catching the energy of a lightning bolt using the capacitive storage? ;) Did you actually managed to do that?
You may connect a chain of small LV caps in parallel to the HV bank - this way you will have many LV sources to transform. Ensure that voltages at all caps are balanced (use TVS for each cap) - all those little sources must be drained simultaneously with the same speed and have precisely the same capacitances.
F.e. use 20 caps 1KV each; then wind 20 equal isolated primaries on a huge toroidal ferrite core with just one secondary. With a step-down flyback topology, synchronously switching on all primaries at once, you will ensure the energy draining will keep all voltages on caps at the same level. Transform this into 12VDC to charge a Lead battery of a UPS, so you will get 120VAC as well. :)
Electra
Thu Apr 03 2014, 10:22PM
I was about to suggest the same sort of idea as Yandersen just pointed out, only using many stages of half bridges in series as the ac would be half the stage bus voltage.
The gate drives transformers would be similarly bulky as would have to isolate 20kv and have as many windings as igbts used. Even if you used the highest voltage devices you could find plus you’d still need some overhead.
While all the options seem to have been discussed from mechanical, vacuum tube or series semiconductor however you arranged them. Also it would have to work over a very wide range of voltage as the capacitor discharged. Most of the energy would be in the higher voltage end of the range, so you could just opt to operate over, for example 3:1 input voltage range.
Thu Apr 03 2014, 11:42PM
Electra wrote ...
He could do Yandersen's ideas and use high speed optocouplers.
Yandersen
Fri Apr 04 2014, 02:43AM
Well, one for sure is that assymetrical halfbridges will be required to charge primaries as coupling factor with 20KV isolation over the core will be too bad.
Most of IC halfbridge drivers have 600V bootstrap voltage, so that will be the limit for a single stage.
As voltage range has wide bounds (0-600V), the time the primaries will build up the desired current level is not constant also (the higher the voltage, the faster the current rises). To control the charge duration without the need of controlling the voltage, we can put a shunt resistor in series with a chain of dividing caps (insert the shunt between Gnd and the "bottom" cap) - once all stages are told to start energising, the voltage drop on a shunt resistor starts to linearly rise. Once it reaches the desired value, we close all stages and wait until the portions of sucked energy will unload into the LV load (flyback topology). Then we start the charging cycle again.
Fri Apr 04 2014, 04:25AM
I've just had a pretty simple idea, use a high value resistor and a high voltage triode to charge a capacitor bank to a pre-determined voltage, say, for arguments sake, 120V (doesn't really matter), then drive whatever load directly from that, (or use an SMPS, or whatever, to 'transform' the voltage to whatever you want.
Just keep turning on the triode to maintain the voltage in the second, low voltage, capacitor bank within the upper and lower limits (whatever you decide).
While this will require a large capacitor bank, and a HV resistor (or string), and a HV triode, it won't require the multitude of sections proposed in some of the suggestions here.
The HV resistor is just to limit the current to a reasonable level to be controlable, and the value could be reduced as the HV capacitor bank becomes depleted. (if you use a string of resistors, just switch some out of the string as the HV capacitors become depleted, maybe in conjunction with switching the triode on for longer periods.)
The current rating of the triode and the total capacitance of the low voltage bank will be dependant on the load being driven.
Artlav
Fri Apr 04 2014, 07:15AM
Artlav Registered Member #8120 Joined: Thu Nov 15 2012, 06:06PM
Ash Small wrote ...
That sounds a lot like a linear regulator.
Thus, efficiency will be 120/20000, or essentially zero.
Right? Or did i read it wrong?
Fri Apr 04 2014, 08:13AM
Artlav wrote ...
You may be right, maths isn't my strong point, but you'll only need sufficient resistance to make the current managable. This will depend on the amount of pulsed current that the triode can handle, and that will depend on what HV triodes are available.
As I=V/R, my calculations suggest that to limit current to, say, 100A pulses, you'd need 200 Ohms.
To limit it to 20A pulses you'd need 1kOhm.
I'd need to google available HV triodes in order to take it any further.
EDIT: I suppose you could use a series string of 20 or so mosfets, I've seen various circuits that can achieve this successfully.
EDIT: Maybe the 1/2CV^2 thing makes this less efficient than other methods, along with the resistor losses. As I said earlier, maths isn't my strong point. I generally just copy formulae into spreadsheets or whatever to do number crunching.
Fri Apr 04 2014, 05:31PM
Use a linear supply to bootstrap a SMPS of some kind with high voltage switching elements.
The other option is electrostatic motor of some kind/version. a plain DC motor *may* be doable, if you figure out some way to build it.
