  • Guests: 66
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
New MMC capacitor design to share
Meatball
Sat Mar 22 2014, 08:04AM Print
Meatball Registered Member #2401 Joined: Mon Sept 28 2009, 04:25PM
Hey all - I thought I might post about my royer induction heater tank cap that I made. I was tired of seeing all the open air point to point construction, so I put together something more robust, and less likely to become damaged without being stuck inside a rigid enclosure. This was also mainly made with uniform current distribution in mind, as well as heat dissipation. The thermal limitations of the tank capacitor are some of the main constraints of the royer induction heater, so this is my personal solution.
Take 18 MKPs all rated well above your expected Vpeak, and arrange them as best you can like so.
Photo1 Zpsee6f0d37
And grab some 25 mil copper plating and make large electrodes for the arrangement.
Photo2 Zps0e61375b
Use thermal epoxy to glue the suckers in place.
Photo4 Zps64fbc80a
Bend your respective pins to its corresponding electrode, and solder.
Photo5 Zps060e6d2b
Add a terminal style of your choice in the center of each electrode. I chose a ring terminal so it could be soldered into the center hole easily, and then perfectly fitted for work coil copper tubing. These terminals are made for 1/4" studs, so I used 1/4" tubing for my work coil.
Photo6 Zps19146f14
I think this design makes for a solid (heavy) MMC construction, and heat dissipation abilities - allowing the caps to sink heat to the plating via thermal epoxy, so they share the current load evenly and also the thermal load evenly. It also makes for an easy way to measure and monitor the temperature of your capacitor, so you can know if your royer induction heater's constraint needs a break. One should feel free to attach a CPU heatsink and fan to either or both electrodes, or even a water block if need be. The surface area this provides is a nice advantage. One should be able to scale this design up to accommodate any current load parameters that are needed.
Photo7 Zps6fc2025f
I hope this can inspire someone to build a 2kW range royer induction heater!
-Tyler
Ash Small
Sat Mar 22 2014, 10:07AM
A very nice piece of work. I plan on building one at some point, but I want a vacuum induction furnace. I guess the way to go is to use a ceramic chamber and have the work coil outside the vacuum chamber, as this avoids outgassing problems from the capacitors, etc., and also aids cooling, but I'm still working on the general layout.
Sat Mar 22 2014, 11:29AM
mister_rf Registered Member #4465 Joined: Wed Apr 18 2012, 08:37AM
May I suggest the second-generation version of the original design? cheesey
1395487734 4465 FT161942 Circle 2
Sat Mar 22 2014, 02:23PM
Very nice, im no expert. but i would suggest removing those lugs and conneting it directly, nice big copper sheets and thick copper tube, only to limit it with a tiny tinned copper joint? Bah!
Ash Small
Sat Mar 22 2014, 03:50PM
Thomas W wrote ...
You could form the tubing into a circle and solder it directly to the copper sheet. This would assist cooling as well.
