  • Guests: 55
12/13 williamn (48)
12/13 ReddyK (57)
12/13 Birdman (31)
changing values of opamp with chip temperature
Sun Mar 09 2014, 05:08PM Print
I am still working on building a precision thermometer (for fun, so no comments that I can buy one).
It uses an RTD probe connected to a LMC6064 opamp for about 3x gain right now. I am working on trying different opamps. The output goes to a 16-bit ADC that ups it another 16x.
I have the probe in an ice bath for hours for a stable temperature. When I turn on the circuit I get a reading - say 23740 out of 32768. Over time, the temperature drifts downward. If I put my warm finger on the opamp the reading starts to drop. So, the chip is sensitive to temperature, and the slight warming from the chip being active is causing an error with my measurements.
Is this the voltage drift I see on the datasheets?
I am going to try another chip, like the op275, with a low voltage drift. Other than this, is there any way to prevent this from happening? All of the other components (resistors) have thermal values of 15ppm/C, so I am good here.
Sun Mar 09 2014, 05:31PM
The LMC6064 datasheet gives 1 uV/C input offset drift typical, x3 x16 = 48 uV/C.
If your voltage reference is say 3.2768 v
with a 16-bit ADC thats about 1 Celcius per bit ...
so if the ic heats up by say 30C, the reading should change by a count of 30
When using 16-bit precision normally minor effects become observable !
e.g. the Seebeck/thermoelectric effect
P.S. ... how many wires to your RTD element?
two = guaranteed problems
three = can compensate quite well
four = reliable reading
the majority of industrial RTD instruments that we repair use three wires and 10 or 12 bit ADC
so for 16-bit I guess four-wire is required.
Dr. Slack
Sun Mar 09 2014, 05:59PM
Please post your full circuit, as it's not clear what you are measuring and with respect to what. For the last little bit of accuracy, the devil really is in the detail.
Raising the total temperature of the opamp could be shifting its voltage offset, or raising one end of it could cause a transient shift while there is a temperature gradient on it, or it could be warming its leads with respect to the wiring on the board or socket which is causing a thermocouple effect. They will all have different mitigations.
Sun Mar 09 2014, 06:50PM
I'm modeling my circuit after the 3-wire design in the article above. I'm using 3-wire because that is the type of probe that I have. I don't need anything crazy precise. I've seen a number of different constant-current designs using the NPN transistor in this article vs opamps in others like here
I am not sure which is better, or if they are both acceptable. Certainly, a minor change in the "constant-current" will impart error.
My DAC is the ADS1115. However, I do use my own non-inverting gain amplifier to take adavantage of the ADS's full-scale, so I can introduce temperature drift error with my opamp.
Again, I'm doing this project for fun and to learn so I am open to all suggestions for the best components to minimize the issues. RIght now I'm playing with it on a breadboard, which also introduces resistance errors. I wiggle one one of the opamp resistors and the ADC reading changes by 30-100.
Bjørn
Sun Mar 09 2014, 08:42PM
Make sure you are not putting any real pressure on the chip since that can affect it too, sometimes significantly.
Sun Mar 09 2014, 09:13PM
Bjørn wrote ...
good point. I was.
