  • Guests: 61
12/13 williamn (48)
12/13 ReddyK (57)
12/13 Birdman (31)
precision voltage source
Fri Mar 07 2014, 03:02PM Print
I need a very stable voltage source. I can set it between 4.1-5.1v as long as it stays at one value with the smallest ripple possible. Right now I have a 7.5v wall adapter that I input into a 5.1v voltage regulator. On a standard volt meter the signal is stable. I will look at it with my digital scope later and see if putting a diode/capacitor or resistor/zenor combination help.
I am looking for advice as to the best way for the most stable voltage output for a precision instrument. Thanks.
Fri Mar 07 2014, 03:33PM
A 5.1 v zener diode has a significant dv/dT characteristic ... not what you want
look for "precision reference" from your supplier.
You may find that the precision that you require is unavailable at your required voltage
but precision resistor dividers can provide any lower reference voltage.
Alex M
Fri Mar 07 2014, 05:04PM
How about a TL431? They are very stable and used in SMPS all the time to as a stable adjustable reference to set the output voltage. It is available in a number of different packages including the familiar TO-92 package.
Product page Link2
Data sheet Link2
Dr. Slack
Fri Mar 07 2014, 05:07PM
removed, rant not helpful
Fri Mar 07 2014, 06:23PM
Dr. Slack wrote ...
Use reasonably low noise amplifiers like OP275 (6nV), not LM324 or TL071, or any low current CMOS stuff.
I will look into this. How would I find a "low-noise" opamp using a datasheet. Is there a particular parameter during the search to fine tune this requirement?
Fri Mar 07 2014, 06:39PM
MAX6126B-SOIC looks cool. Vout 5V, Temp. Coeff ppm/°C = 5, initial accuracy % max = 0.06.
Fri Mar 07 2014, 07:14PM
I've checked out a few of the through-hole voltage reference chips.
What is the difference between a voltage regulator and a voltage reference? Is it the degree of accuracy of maintaining the output constant?
Edit: I see, the reference does not supply current like a regulator. I should have clarified that I need the voltage source to power my opamp and dac.
Fri Mar 07 2014, 11:04PM
The voltage reference provides voltage information to the voltage regulator, so the regulator has some definite value to cling on to.
This paper should give you some practical ideas about how a reference can be used in a precision voltage source: Link2
Dr. Slack
Sat Mar 08 2014, 07:54AM
Sat Mar 08 2014, 10:49AM
Having looked at the datasheet for the MAX6126B as suggested by PM
the 4.096 V should be ideal as a reference for Lithium battery charge/discharge management.
In my opinion, a super-precise reference is not required
as the nominal 4.1 v charging voltage is a fairly loose specification,
with for example no temperature considerations.
(ask Boeing ! )
