Registered Member #5323
I've spent much time searching online for a 10 meg resistor @ 100-200 watts with a 30-40kV flash over spec - or anything close. Looked and looked, checked every vendor that I know. The flash over spec is the sticking point. Helpful guidance will be appreciated.
Registered Member #72
You can get resistors with a few kV very cheaply, so you don't need too high a 'multi' to get there.
Is this for constant disspiation, or for connection to discharge quickly? You might consider a water resistor for pulse discharge. A physically long polythene tube is good for voltage withstanding, water has a huge thermal capacity to absorb pulses, and the varaible value is not too important for energy dump duty. However, for continuous connection as a bleeder, water resistors are not good.
Are you really going to spend 160 watts in constant dissipation across yoour 40kV caps into a fixed bleeder?
To be clear, the recommended way is to buy several lower voltage, lower wattage resistors and connect them in series? (multi-mini resistor).
It is for an experiment illuminating 40 feet of florescent tubes powered by the bank of (10) 40kV caps totaling 70.5uf. Admittedly, the 200 watt spec is too high. I suppose I could come down on the desired resistor wattage to around 100 watts and still have enough of a safety buffer, yes?
Registered Member #543
GammaRay wrote ...
Registered Member #3271
GammaRay wrote ...
This could be of help for high voltage and high wattage. have a look at the second example.
<jedi hand wave> sounds like this is not the project you're looking for <\jedi hand wave>
I'm not saying that discharging your caps slowly through a big resistor and some tubes won't show something, but the only scope you have for drama is if something goes wrong and you blow all your tubes, which is not really the way to plan it.
Now if I had 10 off 40kV large caps, I'd build a marx bank, probably 2x5 stage bipolar, to reduce the peak voltage to ground, and to split the build into two. It's about the right sort of number of caps, and your voltage is high enough to make spark gaps very non-critical, low enough that you won't have insurmountable problems with corona, and you have enough energy there to make some really spectacular planned drama. The components to do it are easy to come by, this is one place where long thin tube water resistors would make excellent interstage charging resistors. One has been built before, have a look at lod.org, the LightningOnDemand website, and their Lorentz gun taser cannon project.
You already know that gloves and boots are little practical use at 40kV, so would be totally irrelevant at the 10 stage output!
