  • Guests: 42
aonomus (38)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
arduino ADC and opamp issue
Sat Feb 15 2014, 11:58PM Print
I have a non-inverting opamp that feeds the output to one of the ADC pins on my ATMEGA328. I read 4.5 volts on the opamp (LC6064), which has a low-offset for my needs. However, despite there being the correct voltage on the arduino, I get less than 0.5, if not lower, reading on the analogread. I probably get about 96 out of 1023.
However, when I swap the opamp with a MC3403 everything works fine.
So, this has something to do with the chip, and I am not sure what parameters on the datasheet would help me figure this out. Can anyone offer some help?
Thanks.
Sun Feb 16 2014, 02:21AM
figured it out.
it has to do with the source impedance and the adc capacitor charge time.
Andy
Sun Feb 16 2014, 03:02AM
IamSmooth, would you beable to take the TC of the cap and resistor and adjust it on the ATMEGA328, Or would that stuff up the resolution?
Sun Feb 16 2014, 05:00AM
How would I get the time constant? I don't know how to measure the internal values. I believe I've read that the cap is about 14pF. The resistance is about 20k for a tC of 800uS. Again, this is what I've read and not measured.
I added a delay of 5ms to solve the problem.
Andy
Sun Feb 16 2014, 05:44AM
I'm not sure, but might run into this problem. Maybe three different accurate voltage sources and the time that it got read with the source voltage max, and brute-force the instantaneous voltage reading.
I think a battery would probable be accurate enough, with multiable samples?
