  • Guests: 31
aonomus (38)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
High voltage transformer?
StormInABottle
Fri Jan 31 2014, 12:45AM Print
StormInABottle Registered Member #9252 Joined: Fri Jan 04 2013, 06:27AM
I finally found a ferrite core available locally. And i recently bought a 2 KG spool of 34 AWG wire so i am going to use it.
Here is the core i found. Link2
Quite the beast i think? I will buy two. And arrange the two I onto one U as to make a large U and a small U. I should have about 25 centimeters of winding length. I will wind 23 Cm of them. Which gives about 1440 turns. Single layer :) I will wind it on a PVC pipe just like a tesla coil. The primary will be 3+3 turns. Hooked up to my IGBT ZVS driver fed straight by the mains. I get about 320VDC out of the rectifier and filter.. Meaning i should have 76800 volts at the secondary. (Not taking into account resonant rise , The fact that i might include a series resonant capacitor on the secondary and all the other stuff)
It will be submerged in oil Ofcourse :P. I am thinking about epoxy coating the secondary. Ideas?
Thoughts? Ideas? Mmm?
Fri Jan 31 2014, 03:08PM
Since you have over 6 miles of wire I guess you'll have some spare,
I'd use several 34awg strands in parallel (like 'Litz' wire) for the primary,
number of parallel strands in primary = Ns/Np
I doubt that you will be able to insulate 76.8 kV at 10's kHz,
Could you use two secondaries arranged as 38-0-38 kV?
(even this will be difficult to reliably insulate)
Could you use an even lower voltage secondary with a voltage multiplier?
I would decide what uses I may have for such a finished transformer, e.g.
C-W multiplier (choose voltage to match available diodes and caps)
Marx Generator (capacitor voltage)
Supply for sgtc (primary capacitor voltage)
e.h.t. bench power supply
etc. etc. ........
StormInABottle
Fri Jan 31 2014, 04:11PM
It will be a single layer. Under oil , epoxy coated. And i will design it to be a Bench power supply , Yes. Reliability is important. That's why i picked the ZVS driver. As it barely heats even when switching 1000 watts+ And i never blew a mosfet or igbt with it
And i need AC. If i ever need DC i would probably use a string of 100 UF4007
I want to do all the experiments that one can do with an X-Ray transformer. But since over here. Even the dental X-Ray used head costs more than the entire cost of the transformer. So i though a DIY approach would be more appropriate.
Fri Jan 31 2014, 06:00PM
StormInABottle wrote ...
A Well made IGBT Fullbridge is a lot more reliable then a ZVS driver as far as i know.
StormInABottle
Fri Jan 31 2014, 06:16PM
Thomas W wrote ...
Well. A SSTC's fullbridge blew lots of mosfets. My ZVS NEVER blew a single mosfet or IGBT
Fri Jan 31 2014, 10:45PM
Have you actually run a 'zvs' from 320 Vdc?
I've had problems doing so.
You need to think about the gate drive circuitry
due to the high dv/dt at the collector
turning on the transistor that should be off via the collector-gate capacitance.
(I think that's the problem)
A separate gate drive circuit may be required, not the usual resistor & zener.
StormInABottle
Sat Feb 01 2014, 12:58AM
I can get good 35W resistors XD.
See this. Link2
His voltage i could find. But 60 extra volts could not do bad right?
I can guess that full (Or half) bridge driver would be horribly similar to steve's SSTC 5? But of course with a different drive circuit?
Antonio
Sat Feb 01 2014, 01:56AM
Have you considered at what frequency this secondary coil will resonate with its own parasitic capacitance?
StormInABottle
Sat Feb 01 2014, 02:16AM
Not yet.
