  • Guests: 30
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
What could i use this capacitor for?
Sat Jan 18 2014, 08:30PM Print
I honestly dont know why i brought it (i actually went on a bidding spree)
Apparently, its a DC link capacitor, anyone got ideas i could use it for, short of a doorstop?
Dr. Slack
Sun Jan 19 2014, 10:32AM
There's all sorts of things you can do with 300J energy. It looks too big to be an electrolytic, and there don't seem to be any polarising marks on/near the terminals, so it looks like it doesn't need the same level of protection against reverse charge that a 'lytic would, if discharged into a coil. Reverse charge after discharge will shorten its life, but it doesn't sound like you are sufficiently emotionally attached to it for that to be an issue.
If it's a DC link cap, it won't deliver a short enough pulse to be any good for can crushing. A disk launcher or rail gun would definitely be on, with the former being infinitely cheaper in terms of time and resources to get something going. Wire vapourising is easy too.
Wind a few turns of heavy, insulated wire into a pancake coil, rest an alli disc (HD platter) on top, and discharge 1400v into it. Loud bang, dent in ceiling or broken light bulb, demonstration of principle, not too much time expended, and you can now relegate it to a door stop.
1400v is just a nice voltage to get from a bipolar pair of doublers, direct from mains, so with a couple of 1000v caps and four 1N4007s, you've got the charger.
Sun Jan 19 2014, 11:16AM
Cool, i shall try that then.
As of now im still waiting for it to arrive here. I have those components around somewhere so i shall deffinatly give the disk launcher a try! :)
do you think 50mm2 cable is a bit too big? :P
Sun Jan 19 2014, 02:08PM
Make a Z pinch, or dense plasma focus (DPF), 300J ought to be enough for a basic experiment.
Won't do much fusion but should be enough to implode a few wires...
Sun Jan 19 2014, 02:38PM
Conundrum wrote ...
Both those things seem a bit expencive for me, also, i do not have any proper vacuum equipment.
Alex M
Sun Jan 19 2014, 05:37PM
Nice find, looks like you got a good price on that.
Sun Jan 19 2014, 05:39PM
Alex1M6 wrote ...
Im quite an expert at looking through ebay and catching the best deals (0-1200v @ 0-20mA spluttering powersupply for £20)
Mon Jan 20 2014, 04:34PM
Thomas, hang onto it until you want to build a good quality 1kV PSU, when it will work wonders as a smoothing capacitor.
Mon Jan 20 2014, 06:32PM
Okey then, i shall :)
mnr
Mon Jan 20 2014, 10:40PM
mnr Registered Member #996 Joined: Sun Sept 09 2007, 06:17PM
I have an identical one to this that I used a few years ago for a small induction coilgun. Mine had no issues with pulse duty, and they have a very low ESL. This exact model isn't listed in the datasheet (http://www.ecicaps.com/pdf/capacitors/ul9-series-dc-link-filter-capacitor.pdf), but you can see from other models in the UL9 series they carry some pretty extreme peak current ratings.
