  • Guests: 59
Cause of IGBT Death
dewald
Sun Jan 12 2014, 11:15AM Print
dewald Registered Member #17114 Joined: Sat May 11 2013, 09:01PM
Hi all.
My name is Dewald, and I'm currently building my second tesla coil, this time medium sized drsstc driven by a full bridge IXGN60N60C2D1. I just fired it up for the first time yesterday evening, and the results were not too bad. I'm assuming it will improve with better tuning. Unfortunately, as I was running with some power (about 250 A peak, 350 VDC) and increasing the interrupter frequency, it suddenly stops, with the bridge shorted out.
I'm pretty sure I have a good, low inductance bridge design, with proper decoupling and plenty of TVS diodes. I'm using a UD2.5 style driver, with some phase lead, although the phase lead might not be optimally trimmed in. Resonant frequency is around 132kHz. I have 7.5 turns of copper tubing in a flat spiral coil together with 60 nF of 942C's.
Edit:
Here is a picture of my h-bridge setup.
What can you say from experience could be the most likely cause for the bridge death? I was sort of expecting at least 500A peak from it. Is improper tuning the culprit? Too long interrupter pulses? Too high resonant frequency? Too slow gate drive? Am I simply expecting too much from my IGBTs? I think I am starting to understand most if the system, but I don't really get the failure mechanisms.
Edit:
Here is a video of the initial run, including the point where the bridge dies. No explosions, no bangs, just stops.
http://youtu.be/ai5g96i3Y20
Sun Jan 12 2014, 01:30PM
Hi,
Apart from bad layout, which you mentioned is all right, the other most common causes for IGBT failures in a DRSSTC are:
-Bad gate waveform
-Insufficient dead time (cross conduction)
-Exceeding the Switching (turn-off) SOA which causes the IGBT to latch
-Plain and simple junction overheating (by peak junction temperature), usually caused by switching losses and longer ON-times. Look the transient thermal impedance graph in the datasheet.
dewald
Sun Jan 12 2014, 02:47PM
Thanks for your reply Dr. Dark Current.
I am thinking that my gate drive might be a little slow. I see people are generally driving the gates up to +-24V. I am using 4 x MIC4452 (12A, 18V drivers), two for each half, at 18V. I mainly simplified the gate drive because I did not plan on driving huge IGBT bricks. Is there a great advantage in overdriving the gates in terms of switching losses?
dewald
Sun Jan 12 2014, 02:52PM
I'll try to post some pictures of gate waveforms when I've managed to replace the dead devices.
Sun Jan 12 2014, 02:56PM
People usually overdrive the gates if they plan running peak currents (much) larger than the datasheet maximum, where desaturation could happen. If the datasheet maximum is 300 amps, and you plan running on 500 amps, 18 volts on the gate is perfectly sufficient. The gate drive voltage doesn't affect switching losses much.
dewald
Sun Jan 12 2014, 03:11PM
Ok thanks. Do you have any guidelines about how fast the gate rise and fall times should be? I remember seeing >100ns when I last checked.
To me it sounds a bit like plain and simple overheating. It happens at higher interrupter frequencies, which means high duty cycle as the pulse width remains the same. I do know I was a bit short on heat sink compound the last time I mounted everything together...
Sun Jan 12 2014, 03:23PM
Yes, it could be overheating. The duty cycle in a standard DRSSTC should probably not exceed some 2%. 100 ns is from my point of view way too fast, few hundred ns should be OK (probably up to 1us for larger bricks). A too fast switching can destroy the transistors by voltage overshoot.
