  • Guests: 42
Digispark (ATTiny85) SSTC Interrupter
Sigurthr
Sat Jan 04 2014, 03:43AM Print
Hello everyone! I wasn't sure whether to put this in the comp sci area, the projects area, or here, but since it is for TC use I figure here is best as it is the most frequented/searched area of the three.
I recently built a programmable SSTC Interrupter using the Digispark (Link2) ATTiny85 platform. I heavily modified code by another 4HV member, Gao Guangyan (Loneoceans), with his permission. In keeping with his generosity and the OpenSource spirit, I wanted to release the code for others to use. The bulk of the work is Gao's, I simply ported it to the Digispark, adjusted frequency range to double, increased pulse width range by 500%, and added a CW Mode feature.
All you need is a Digispark (~$8), two 10k pots, and a SPDT On/On switch (you could use a SPST + a pull down resistor too), and a computer with a USB port to get it running. The circuit easily powers from a 9V battery and directly interfaces with a FB-129 fiber optic transmitter, if you so choose to. The nice thing about the Digispark is that no Arduino is needed to program the ATTiny85 MCU. For someone not looking to spend a lot to get a foot in the door of MCU programming who has simple needs, it is the way to go. The Digispark uses a free, modified version of the Arduino IDE, available on their site.
Results: 1.8-418Hz @ 0.05% - 48.8% duty cycle in interrupter mode. The code is for 2-512Hz but the ATTiny85 internal clock on my Digispark is about 20% slow. I read somewhere you can adjust the internal oscillator calibration with code but not wanting to break a working program trying to get it to work I figure better just leave it. The range is plenty for SSTC use.
Arduino IDE CODE:
  Sigurthr's Digispark SSTC Interrupter!
  By Matt Giordano
  Based heavily on ATTiny45/85 code for a simple Solid State Tesla Coil Interrupter
  By Gao Guangyan, <www.loneoceans.com/labs/>
  Thank you Gao!
  offThresh allows the user to turn off the interrupter
  by turning the potentiometer for BPS to below a certain threshold.
  E.g. with Threshold set at 5/1023 --> 24mV, the signals will be off.
  Set Threshold to 0 for always-on operation.
  Digispark Physical Pinout:
    Pin 5 as Digital Input: CW/Interrupted Mode switch.
    Pin 4 as Analog Input: Frequency.
    Pin 3 as Analog Input: Pulse-Width.
    Pin 1 as Digital Output: LED.
    Pin 0 as Digital Output: Fiber Optic Tx.
  For the above analog inputs use a 10k Ohm pot with center wiper to associated
  pin, one side to 5V and the other side to GND. For Pin 5 use a SPDT On/On
  switch with center pin to Pin 5 and one side pin to ground, the other side pin to 5V.
// User Modifiable Variables Here
float maxontime = 5000;     // us - no greater than (32768/5) or 6553us!!
int offThresh = 0;          // Define (offTresh/1023 * 5)Volts as off-threshold
float duty = 0.5;           // Max Duty Cycle desired (here it's 10%)
// User Modifiable Variables End
int vpw;
int vbps;
int vcw;
int critfreq = (1000000*duty)/maxontime;  // Hertz
float ontime = 0;   // always us
float offtime = 0;  // ms or us
float freq;         // BPS Hertz
float period;       // us
int outPin = 0;
int ledPin = 1;
int bpsPin = 2;
int pwPin = 3;
int cwPin = 5;
void setup() {
  pinMode(outPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
void loop() {
  vpw = analogRead(pwPin)-offThresh; // read pw voltage
  vbps = analogRead(bpsPin);       // read bps voltage
  vcw = digitalRead(cwPin);       // read cw switch state
  if (vcw == HIGH) {
    digitalWrite(outPin, HIGH);
    digitalWrite(ledPin, HIGH);
  else {
  if (vpw < 0){
    // Force logic low output when pw voltage is pulled low
    digitalWrite(outPin, LOW);      // Off
    digitalWrite(ledPin, LOW);      // Off
    delayMicroseconds(100);         // Short delay
  else {
      freq = 1 + ((vbps+2)/2);
      // sets max BPS to 512.
      // change to ((vbps+4)/4) for 254Hz max.
      // change to ((vbps+1)/1) for 1024Hz max.
        If the period becomes > 2^15 us (T = 32.768ms or f less than 30.51Hz), then
      the period variable runs over! Hence, we make sure this doesn't happen by
      counting the numbers in milliseconds instead of microseconds.
        Else, we can be free to count in microseconds
      if (freq < 31){
        period = (1.0/freq)*1000;               // ms
        // Since 31 is a very low frequency, it will not exceed our
        // pulse width at 10% duty cycle, so we just calc ontime in us.
        ontime = 1 + (vpw/1023.0) * maxontime;  // us
        if (ontime > maxontime){ontime = maxontime;}
        offtime = period - ontime/1000; // period in ms
        // Now send the output signals
        digitalWrite(outPin, HIGH);     // On
        digitalWrite(ledPin, HIGH);     // On
        delayMicroseconds(ontime);      // delay in us
        delay(offtime);                 // delay in ms
      else {
        period = (1.0/freq)*1000000;     // us
        if (freq > critfreq){
            ontime = 1 + (vpw/1023.0)*period*duty;    // period in us
        else{ontime = 1 + (vpw/1023.0)*maxontime;}   // period in us
        // Calculate off-times, capping the on-time to some max
        offtime = period - ontime;      // period in us
        // Now send the output signals in microseconds
        delayMicroseconds(offtime);     // delay in us
Terry Fritz
Sun Jan 05 2014, 08:58PM
I use the ATTINY85 all the time too and the internal clock is supposed to be 8MHz +-10% (factory calibrated). However I think they very far more than that too. You can adjust it if you really want to but it is easier just to use a wider range of adjustment if you can in software. The frequency also varies a lot with temperature and voltage. I might be easier just to add a simple Cermaic oscillator to the circuit rather than trying to adjust it. But on the 85 that needs two pins you might not want to spare.
The data sheet has the details on how to adjust the clock. It is done with the OSCCAL register and all so it would require messing with the software and all the risks that has.
Sigurthr
Sun Jan 05 2014, 11:03PM
Absolutely right. That is part of the reason I decided to just double the frequency range in software and point out to others via notes where it can be increased again if needed. It doesn't seem worth it to risk breaking the program to get an extra 100Hz or so out on the top end.
I had thought about using a xtal to get a better clock speed but I'm already using 5 I/O pins, so no point. One is just for an indicator LED and could be done without but it isn't worth it really, as you pointed out.
Also, I read somewhere that the 85s are locked to 1MHz and require a special bit fusing to get them to 8MHz. I'm new to using uC's so I haven't looked into using OSCCAL and the like.
Terry Fritz
Mon Jan 06 2014, 05:50PM
The uC's clock speed is actually 8MHz right now but there is a divide by 8 clock pre-scaler that reduces that to 1MHz. In Atmel's Studio programming software you can simply disable that fuse bit and then it runs just fine at 8MHz. The bit is called "CLK/8" and the default is enabled. Atmel's uC's seems super stable at higher clock speeds even in exteme environments.
Another easier way to calibrate the clock is just to know the thing is going to be all wrong and have a calibration variable to correct it. In a device I am working on you just calibrate the clock in software along with voltage and current sensors. But you would need a frequency counter or some other standard to calibrate it against in that case. Using the clock's cal register for calibration seems pretty messy from the little I have studied it. It seems easier to me just to fix the clock in software.
BTW - Some very cheap modern watches now have very very high accuracy.
Instead of reying on the raw quartz crystal for accuracy, they are calibrated at the factory with software in it's uC brain. So if the 32,768 Hz crystal is really 32,779 Hz, a varible in the little software it has just modifies the counter to correct for any error. Some chips also have temperature calibration. Thus your really cheap watch has very high accuracy at a very tiny added cost.
BBTW - If you can, program the ATTINY85 in what's called the "high voltage" programming mode. Then you can recover the chip if you lock it all up and you can play with more bits. The standard ISP mode is sort of limited if you are experimenting.
The only one to really watch is the "clock type". If you program it for a crystal and you have a ceramic ocillator instead, it will have zero clock and that is pretty hard to fix without an external clock source and other complex things. That is more of a concern on the more expensive or hard installed chips you just don't want to throw away.
