  • Guests: 79
plazmatron (48)
rm203tech (17)
Duality (16)
Jiffycoil (65)
Dandrion (69)
12/21 Inducktion (32)
12/21 Standa (31)
12/21 nabzim (33)
Dismal fail
Sat Dec 21 2013, 10:29AM Print
Has anyone seen a worse soldering job? Post it here!
-A
Sat Dec 21 2013, 10:44AM
Conundrum wrote ...
Everyone has to learn soldering, André, and some are more gifted than others.
To set up a thread ridiculing the mistakes of others could be thought to lack Charity.
Sigurthr
Sat Dec 21 2013, 10:46AM
Wow... That is just painful to look at, seriously. Next year I am going to start selling some PCBs I designed and I REALLY hope I don't run in to anything like this.
Andy
Sat Dec 21 2013, 06:49PM
The sad thing is I could probable top that sad cheesey
Sun Dec 22 2013, 05:50AM
PM, to be fair its not even GCSE level quality.
also the guy who built this couldn't even put the parts in the right way round OR the right locations!
I'm all for people learning to solder properly, but this should be used as an example of what NOT to do smile
(note to self: found one of my old boards a while back, that said the quality was pretty good considering)
Alex M
Sun Dec 22 2013, 01:49PM
Here is the first thing I ever soldered from several years ago. Electronics wasn't part of my schools curriculum so I had to learn everything on my own accord. I still blame it on the cheap soldering iron and included lead free solder I was using tongue
Top side looks relatively normal.
1387719087 3943 FT159802 Dsc 5200
But flip it over and it resembles something like Birmingham from above.
1387719140 3943 FT159802 Dsc 5159
Surprisingly it worked first time though.
Is anyone else having blank page problems when uploading .jpeg photos? I had to convert to .gif for the above photos to upload.
Wed Dec 25 2013, 05:54PM
I have a picture here which is worse even than this.
Its a Bluetooth speaker which failed completely and refused to charge due to a broken joint on the miniUSB.
In this case the positive lead for the battery was uninsulated, bent over and 2mm away from shorting out and possibly causing a fire if the speaker was just knocked.
Soldering all over the board was marginal, even the speaker connector required reworking.
Can't even see a safety OC/OD circuit on the battery, thats how bad this is.
The MP3 player and speaker set was even worse, no safety circuit or even a regulator.
Battery -- diode-- USB V+.
Diode was a silicon with 0.57V drop, so battery voltage fully dependent on USB voltage which meant it could go up beyond 4.4V worst case.
AND the memory card was FakeFlash 252MB marked as 1GB.
-A
Sun Dec 29 2013, 05:04AM
When I 100% had to have a light intensity -> audio signal circuit in less than an hour. I went on to use this to play back audio recorded onto 35mm still camera film.
1
Wed Jan 01 2014, 09:52AM
Nice, thats prototyping at its finest.
