  • Guests: 56
Can I use dual 'speaker wire' for a primary?
Cheezey
Sun Dec 15 2013, 11:54PM Print
Cheezey Registered Member #28483 Joined: Fri Jul 12 2013, 09:00PM
First off, hi! This is my first post here; I'm excited to join the community.
Anyway, I'm working on my first Tesla coil, based off of Steve Ward's MiniSSTC design. I found some wire laying around that might work for the primary, but it's a little thin. However, it's speaker wire (Edit: zip cord), two wires with their insulation connected. If I didn't separate them and just connected the two wires together at each end, would it work?
Thanks!
Dr. Slack
Wed Dec 18 2013, 08:23AM
That will work just fine. Fatter wire may work very slightly better, but it's more important to get something reasonable going first. You probably never will upgrade just the primary, but build a bigger and better of everything next.
Wed Dec 18 2013, 11:05AM
For an SSTC, almost anything will do. I have used three wire extension cord cables with great success, with all of the wires paralleled. You can also series them if you wish to.
Cheezey
Sat Dec 21 2013, 09:37PM
Alright, thanks.
Sun Dec 22 2013, 02:53PM
Absolutely.
The only potential issue is that there are lots of speaker wire out there that are made from aluminum and not copper. This is especially true of low cost speaker wire. However, even aluminum shouldn't be a big deal for tesla coil use as some of the largest tesla coils use aluminum for primaries (i.e. aluminum flashing), but just something to be considered if you are to run your coil at very high frequencies.
Cheezey
Sun Dec 22 2013, 07:42PM
EasternVoltageResearch wrote ...
Absolutely.
It's copper.
Thu Dec 26 2013, 04:54PM
Then that should be fine for your Tesla coil. Just remember, the insulation may not be rated for the higher voltages (i.e. 300V or 600V) that is typical with most hook-up wire, so you may have to pay more attention how you route your wire from your driver board to the primary coil. In otherwords, be careful about it coming close to earth ground or other connection points so that it doesn't arc through the insulation.
But other than that, its perfectly fine for your application.
