  • Guests: 34
Difference between DRSSTC and Series resonant converter
hsieh
Tue Dec 03 2013, 12:08PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
What's the difference between DRSSTC and series resonant converter Link2 ? DRSSTC has a resonant secondary while series resonant converter doesn't?
Tue Dec 03 2013, 12:56PM
The difference is that a Tesla coil produces sparks and this circuit does not. tongue Also:
-The series resonant converter is single resonant
-The resonance in the series resonant converter occurs between the leakage inductance of the transformer, or additional series inductance, and the capacitor
-The series resonant converter is a constant output voltage non-regulated power supply.
Tue Dec 03 2013, 02:41PM
There are actually several patents regarding high voltage generators that describe DRSSTC topology and its double resonant driving scheme exactly. The topology and driving mechanism isn't not new at all, although in the patents, the output voltages are much less than what we would use in a DRSSTC.
Just a quick look found this double resonant driver which was intended for gas lamps. If you read through all the legal speak, you can see its very similar to how DRSSTCs are driven.
Antonio
Sat Dec 07 2013, 11:32AM
The schematic in the patent (actually from one of the versions) is very different from a "conventional" drsstc. I understand the drsstc as a circuit that generates the same output of a triple resonance Tesla transformer, or a "magnifier", but with excitation through an AC driver instead of capacitor discharge. It uses the zero-state response of the network instead of the zero-input response.
Phillip Slawinski
Thu Dec 12 2013, 07:31PM
Phillip Slawinski Registered Member #1732 Joined: Thu Oct 02 2008, 02:34PM
Dr. Dark Current wrote ...
This is not strictly true. I know because I've made a modulated SLR before. It's what I used to drive my SSVC (Solid State Valve Coil).
