  • Guests: 62
IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
Measuring drsstc primary current, please educate me
Hartstart
Tue Nov 26 2013, 09:14AM Print
Hartstart Registered Member #2616 Joined: Sun Jan 10 2010, 01:00PM
Hi!
If I have scope shot like this:
1385456316 2616 FT0 Img 5238
When speaking about drsstc primary current, is this 260Apk or 520Apk if we assume 100A/Div
Tue Nov 26 2013, 04:33PM
it looks to me like it swings between -260 ish, and +260 ish Amps. it spans 520 amps. what else do you want to know? you can use RMS to figure out the rest.
Hartstart
Tue Nov 26 2013, 06:15PM
Reason why I was asking is because i got confused about the way people set their over current detection.
This signal gets rectified and fed into a comparator. Then you have roughly half of the full swing so if I have 1:1000 current sensor and 5ohm load I have to set my comparator to trigger at 1.25V to get 500A limit?
Tue Nov 26 2013, 08:02PM
Hartstart wrote ...
i dont do too much of the tesla coiling anymore, so its best to ask some of the other aces who do it all the time. But generally in these type of circuits, your calculating the safe operating area/envelope of the device that needs to be protected. then your averaging out the feedback measurement to intervene as you approach the boundary of the SOA.
then magnitude, duration and hysteresis of this feedback circuit are chosen to avoid things like false triggering or oscilations and flickers...
Hartstart
Wed Nov 27 2013, 08:30PM
Driver and other parts are working just as they should (wards UD) but im just not sure how you guys measure your primary current value.
In short: is the "primary current" peak-to-peak value or from zero line to tallest peak?
Uspring
Thu Nov 28 2013, 09:41AM
Standard practice is to call "peak current" the max current, i.e. from zero line to peak.
Hartstart
Thu Nov 28 2013, 10:45AM
Uspring wrote ...
Myth confirmed: I am a biig derp. cheesey
Basicly what this means is that I have been running all of my coils at roughly half of the intended current
Now lets go ahead and double that comparator reference voltage!
Thu Nov 28 2013, 02:20PM
If you look in the schematics for the universal driver, you will see that the OCD signal from the CT is going through a full bridge rectifier, so all peaks, negative or positive are considered by the comparator as zero to positive peak voltages.
