  • Guests: 72
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
Small CNC Mill - mechanics finished
Dr. H.
Sat Nov 23 2013, 07:37AM Print
Good day guys
It's been a while since I've posted something (or done anything interesting in that matter) but I finally found some time to start a new project. It is a small "precision" cnc mill. Some of you might remember this thread:
The old machine is big , pain in the ass to move and not really worth doing small stuff (not very precise).. but has been serving faithfully smile . So it was finally a time to start on that small "tabletop" machine I've been dreaming about. This time it will use ball lead screws and better linear guides. The thing will be driven with servo motors (X, Y) and a stepper for the Z. Here is a crappy picture of most of the linear components:
1385192069 931 FT0 Parts Cnc
After about two months of fiddling here is the "final" 3D assembly of the CNC:
1385192070 931 FT0 Frontview Cnc
1385192070 931 FT0 Backview Cnc
Dr. H.
Tue Nov 26 2013, 09:12PM
Hi guys
I've started cutting some parts. As the big machine hasn't been running for quite a while I've decided to start with something small. So here are the first plexi parts
1385500317 931 FT159100 Pic 121231
Dr. H.
Wed Nov 27 2013, 06:16PM
Hi guys
few more parts for the mill. Also the power supply arrived today. It is a 24V 20A Mean Well SMPS. Of course the first thing to do was to take it apart cheesey
Cheers
1385576195 931 FT159100 Img 20131127 200604
1385576195 931 FT159100 Img 20131127 135843
1385576195 931 FT159100 Img 20131127 200656
Wed Nov 27 2013, 11:25PM
How much did that SMPS cost ? Where did you get it?
I have my bridge frame mill pics somewhere here on the forum...
Dr. H.
Sat Nov 30 2013, 08:16PM
Hi guys. Few new parts cut today.
Hi Patrick - the power supply is from a local dealer of Mean Well. It costs about 180$ including taxes.
Cheers smile
1385842573 931 FT159100 Img 20131130 220708
Dr. H.
Sun Dec 01 2013, 06:27PM
Hi guys - some new parts today - motor couplers and small shaft holders. I've cut them from ertacetal - first time working with this material and it is great - really easy to cut and in the meantime strong and a bit flexible.
Cheers
1385922424 931 FT159100 Img 20131124 153006
1385922424 931 FT159100 Img 20131201 201713
woodchuck
Mon Dec 02 2013, 04:35AM
woodchuck Registered Member #39190 Joined: Sat Oct 26 2013, 09:15AM
Great looking parts! Who needs a 3D printer if you can crank them out like that!?
Dr. H.
Wed Dec 04 2013, 08:22PM
Hi guys
few more plexy parts. With those most of the "soft" parts are done. Time to start cutting that aluminum. About 3D printing - I've seen a professional 3D printer and the stuff produced by it - it can do amazing stuff smile
1386188514 931 FT159100 Img 20131204 220743
1386188514 931 FT159100 Img 20131204 220752
dingo27
Mon Dec 09 2013, 12:28PM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Interesting to see, maybe i will look for some ideas in my projects :)
It looks quite easy to build if you can produce your own parts
I keep my fingers crossed, keep up with good work
Carbon_Rod
Tue Dec 10 2013, 01:40AM
@Dr. H.
The mini mill we have is based on a rebuilt Taig, and runs off the same PC power supply for LinuxCNC (EMC). For a little XYZ system like yours, HeeksCNC would handle most of the gcode CAM for you..
wink
We also have a Prusa calibrated for ABS or PLA, and it does parts even the 5-axis would find impossible. For example, we've printed the Tesla valve-conduit as a single piece for fun. Note too, there are people who simply added extruder chucks (4th-axis A drive) to their mills, and indeed Slic3r will export gcode for EMC in “general” settings....
Some people 3D print in PLA, as the starch based plastic burns out of a sand mold. Then take the rough cast shapes to mill to tolerances on the CNC. However, uttering tolerances in the same breath as plastic or aluminum mills is a bit of a joke.
wink
I have to try 3D printing a solder mask next....
Rod
