  • Guests: 49
How many drivers have you killed? (And general silicon graveyard thread)
Feathers
Sat Nov 23 2013, 06:10AM Print
Feathers Registered Member #10052 Joined: Thu Feb 07 2013, 11:31PM
How many UD's have you killed? What do you think went wrong, and what do you do differently now?
Any other carnage to share?
Here's my boneyard:
I think arc current found it's way through building mains and back to the driver to kill the first two, the third had trouble from the start.
11005077703 B1101c2659
I run a counterpoise ground now, and pay more careful attention to where the coil is set up.
I would include a pile of NST's I've killed, but I didn't feel like lugging them around for a picture.
What are your stories?
Sat Nov 23 2013, 09:11AM
I have only killed MOSFET driver ICs, working with SSTC, never totalled a complete board, at most burn some component, replace and do sparks again.
I used to have a matchbox with exploded silicon, but not more than that. Maybe I nurse my stuff too much ;)
TwirlyWhirly555
Sat Nov 23 2013, 09:44AM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Ive killed gate drive ICs , Many mosfets , few IGBTs mostly due to SSTC building .
Sat Nov 23 2013, 10:14AM
Many dead gate drivers, but that was before I knew exactly what I was doing, and most of them failed while the bridge was not connected/unpowered, I was experimenting a lot with circuits tongue
A disconnected input terminal is often enough to destroy a gate drive IC. It can start oscillating at tens of MHz and fry itself by switching losses.
Kizmo
Sat Nov 23 2013, 11:50AM
Tank circuit wiring melted its insulation and tank capacitor got shorted directly to the output of the bridge cheesey
Nice pop, sparks and fire.. RIP 150Amp semikron
1385207378 599 FT159099 Dead2
Less power and heavier wiring fixed this problem.
Jrz126
Sat Nov 23 2013, 02:50PM
Here's what happens when the cooling blower fails and nobody notices. The blower pressure safety switch was miswired.
PgyUUl
Was pushing 1000HP at the time. People on the other end of the building thought it was a gun shot.
higher resolution
Cheezey
Sat Dec 21 2013, 11:08PM
Cheezey Registered Member #28483 Joined: Fri Jul 12 2013, 09:00PM
Jrz126 wrote ...
Wow. I think you win this thread.
I haven't blown up a single driver circuit. It's probably because I haven't finished a tesla coil yet :P
