  • Guests: 66
12/25 Kolas (18)
12/26 buxtronix (50)
Bizarre battery birth
Sat Nov 23 2013, 04:50AM Print
The other day I was testing a bunch of old dry cells.
Found a 9-volt battery which had spontaneously delivered, through the bottom of the case, one of its AAAA-like cylindrical cells.
Who's seen that happen before? I sure hope it's as rare as coffin birth.
1385182188 2099 FT0 Dscn7061cr
Bjørn
Sat Nov 23 2013, 11:54AM
I have had that happening with 30 mA reverse current. I know of one 4HV member that had it happen under normal use so it happens from time to time.
Sat Nov 23 2013, 03:58PM
Had one explode before, I think its internal gassing.
Nice pic btw, just shows how the strangest things can happen.
I'm amazed this doesen't happen more often with cheap imported batteries, usually they quality check them but evidently in this case not.
9v's are prohibited in international mail unless in their original packaging...
Alex M
Sat Nov 23 2013, 06:44PM
I've had the top blow off one once when it was sitting on a shelf for a few months. It gets quite cold in here during the winter nights so it could be temperature related.
Sun Nov 24 2013, 10:56AM
If you connect two 9V together, this will happen too ;)
Ash Small
Sun Nov 24 2013, 11:42AM
klugesmith wrote ...
Cell replication??? smile
radiotech
Mon Nov 25 2013, 10:09AM
I seem to remember the iron rod coming out too.
