  • Guests: 34
Is there a graph of...
Tetris
Mon Nov 18 2013, 10:33PM Print
The rate at which members join 4HV? When I joined 4HV in Jul 2011, there were only 4K people here. Bit over two years later and there's over 40K members? Earlier this year it wasn't even 10K. What happened to make everyone suddenly join 4HV? I'm curious to see a graph of this... I want to plot a regression line on it to see the rate of 4HV's projected growth... is there any way I can easily obtain a table of the member's join dates/member number so I can crunch some numbers on it? Then again, I'm not sure what I'd use to crunch that much data... Excel if I remember correctly can hold only up to 9999 rows of data...
Shrad
Mon Nov 18 2013, 10:44PM
python + scipy & numpy & matplotlib
Tetris
Mon Nov 18 2013, 11:02PM
Shrad wrote ...
You're talking to someone that barely knows Java and is in the process of learning it.
GluD
Tue Nov 19 2013, 02:54PM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
In the box on the left called "Online" it claims there is, at the time I am writing this, 2581 members.
That is a considerably more sensible number than 40k in my opinion.
Perhaps the 40k figure is all the people who have ever been a "member" here, including spammers and others who have been banned/deleted?
Tue Nov 19 2013, 06:19PM
I see the 2851 number too... where are you looking AshPOD, and seeing 40k?
the_anomaly
Wed Nov 20 2013, 10:05PM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
Click on the members link and you will see. I saw this the other day and wondered too.
Shrad
Thu Nov 21 2013, 10:03AM
ASHPoD wrote ...
Shrad wrote ...
python is easier than java, and with those libraries you have the exact same capacities as matlab or any other pro package
learning a language is only a matter of weeks to get used to the syntax, and besides that if you get the correct philosophy you'll be able to learn any simple language as python, C or java in a matter of weeks
it's a bit like getting stuck on the SGTC principle and not learn SSTC or DRSSTC, you don't get the juice of it :)
but I understand totally that it may not be straightforward for all
python has the advantage of a console-driven execution, so you can do something like
declare matrix_var matrix
load "data.txt" into matrix_var
-- do anything you need with the matrix, like divide by another one, or mask, or anything using numpy functions
open plot
setplotwidth(x)
setplotheight(y)
plot(matrix_var, interpolation, graph_type, ...)
display plot
it can be done in something like under ten lines of code dynamically
there are also some commands to fetch data from sources like databases or online files, etc...
Uspring
Thu Nov 21 2013, 10:46AM
Possibly it is due to this: (posted by our head admin Chris Russell in Feb 12)
Just a quick note to let everyone know that 4hv.org is currently under attack from a botnet. The botnet is spamming the forum incessantly, and so far IP bans have not been effective. The botnet has apparently been creating users for this purpose for the better part of a year, so I've had to go back and delete all accounts that appear to be inactive. Apologies if you're a lurker who has been caught up in this sweep.
Tetris
Fri Nov 22 2013, 02:03AM
Patrick wrote ...
One of the members here had a Member # of over 40k. The number on the left and his number...
Ash Small
Sat Nov 23 2013, 02:57PM
ASHPoD wrote ...
Patrick wrote ...
If you click on the 'Members' link in the top left hand corner you get 130 pages of 40550 members and the times and dates that they joined. All the info you require for your graph is there. Good luck smile
